My Non-Smart Trainer Is Not Listed — Can I Still Use TrainerRoad?
If your non-smart trainer is not listed in the Equipment Checker, there’s a good chance you can still train with TrainerRoad using VirtualPower. You can do this by using the power curve from one of our supported trainers.
How to Train with Your Unlisted Non-Smart Trainer
Use VirtualPower. VirtualPower allows riders to train with power derive power readings without a power meter or smart trainer. A speed sensor and non-smart trainer are all you need.
How it all works: Every trainer make and model has a unique speed-to-power ratio — this is known as the trainer's "power curve." TrainerRoad takes the speed readings from a rider's speed sensor and uses those to calculate VirtualPower based on the trainer's unique power curve.
Your Solution: When you own a non-smart trainer we do not support, you can use the power curve of another trainer we support to train with VirtualPower.
Won't using a different power curve make my power less accurate?
Yes, but when it comes to training with VirtualPower, precision and consistency are much more important than accuracy. Even if your VirtualPower readings are not 100% representative of your outdoor power, you can still reap the benefits of training with power as long as you use the same trainer and power curve for each workout. Doing so means your results will be comparable, and you'll be able to track your progress.
How to Find a Compatible Power Curve for Your Unlisted Non-Smart Trainer
Non-smart trainers come in three varieties classified by how they apply resistance: fluid, magnetic, and wind. The three different types of trainers have slightly different power curves. So, when it comes to finding a compatible curve for your trainer, the most important thing is to choose a curve that matches the type of trainer you have. For example, if you have a magnetic trainer, you'll want to use the power curve from another supported magnetic trainer.
This quick guide should help:
If you own a Fluid Trainer
These trainers use fluid chambers to produce resistance. They have non-linear, exponential power curves, which means that as the rider increases their speed, they will encounter more resistance.
Compatible power curves we commonly recommend are:
  • CycleOps Fluid 2
  • Giant Cyclotron Fluid
  • Kurt Kinetic Road Machine
If You Own a Magnetic Trainer
These trainers use a magnetic flywheel that creates resistance for the rear tire. These trainers have multiple resistance levels that you can usually change by using a tethered hand brake. They have linear power curves, which means that the same amount of resistance is applied regardless of how fast you're pedaling.
  • Elite Mag (5 resistance levels)
  • Tacx i-magic (7 resistance levels)
  • Kurt Kinetic Mag (9 resistance levels)
If You Own a Wind Trainer
These trainers use a fan that is powered by the cyclist’s legs. Similar to fluid trainers, wind trainers have non-linear, exponential power. This means that they provide more resistance the faster you pedal.
  • Kurt Kinetic Cyclone
  • CycleOps Wind
How to Set Up VirtualPower in the TrainerRoad App
Step 1: From the TrainerRoad app, click on the “Devices” tab. This will take you to a screen where you can choose to train with VirtualPower.
Step 2: Select VirtualPower, and from the next screen, check the box to “Enable VirtualPower,” and select the Manufacturer and Model of the supported trainer you think would have a compatible power curve for your unlisted non-smart trainer.
Step 3: Click "Close."  If VirtualPower is highlighted in green, you're good to go!
What to Do After You’ve Found a Compatible Power Curve for Your Non-Smart Trainer
Test your chosen power curve with a “Free Ride.” Free Rides are workouts that do not have power targets. You can find one in the app by searching the Workout Page for “Free Ride.”
Note: It can take a little trial and error to find a good power curve for your non-supported, non-smart trainer. Before diving into a training plan, we recommend you doing a couple Free Rides to test out a few different curves to discover which one is best for you.
Once you’ve found a power curve that works for your unlisted non-smart trainer, it’s important to stick with it. Using the same power source, and thus power curve, is critical in training with power. Without this kind of consistency, the precision and effectiveness of your training will be greatly compromised.
Worried This Solution is Not for You?
If you start training with your unlisted non-smart trainer and discover this solution is not right for you, you have 30 days upon signing up for TrainerRoad to get your money back. No questions asked.
Still Have Questions?
If you need help finding a power curve for your unlisted non-smart trainer, or have another question for us, reach out to our support team at support@trainerroad.com.
Contact Support
Powered by Zendesk
