Solving WiFi Interference
It's possible for WiFi routers to interfere with your ANT+ devices. ANT+ runs on 2.4 GHz, so interference is likely to occur if your router is also on 2.4 GHz and near your bike setup. Luckily, it's fairly simple to switch your WiFi's channel.
Test it
The check for this is to test your ANT+ or Bluetooth devices with TrainerRoad while the WiFi is turned off. If the device signal improves, then it's probably the WiFi that's the problem.
Change the WiFi Channel
If this helps the problem, then it’s most likely that the wireless channels are clashing with each other. Fortunately, changing the WiFi channel is pretty easy.
 Learn how to change your WiFi channel.
Not the Wifi?
Don't think WiFi is the problem? Check out more articles on connecting devices.
Have more questions? Submit a request
Comments
  • Avatar
    Sylvester Jakubowski
    Any particular channel has worked best or is it use case specific? Is there a particular band that ANT+ uses in 2.4ghz? Switching to Channel 1 seems to have improved signal drops for me when monitoring the devices in TR.
  • Avatar
    Andy Fleming
    Changing the wifi channel worked for me
Powered by Zendesk
