Quarq Power Meter
How To: Pair an ANT+ Power Meter
TrainerRoad will collect and display power data from all models of Quarq power meters using ANT+. Learn more about ANT+ connectivity.
How to Pair Your Quarq with TrainerRoad
1. Open the TrainerRoad application and go to the Devices tab.
2. Click the "Pair" button that corresponds with Power Meter.
3. Wait for your Quarq to pair with TrainerRoad
"Searching for device" will be displayed until TrainerRoad discovers your power meter.
4. Your Quarq is Now Paired
The pairing box will turn green once your Quarq is paired with TrainerRoad. You'll be able to view power, cadence, the Quarq's signal strength, hours since your battery has been replaced, and a button to manually zero your power meter.
5. Manually Zero Your Quarq
Manually zeroing your power meter is akin to zeroing a scale before measuring your weight. Hit the Manual Zero button to complete this process. Although this step isn't required to start a workout, we recommend zeroing your Quarq before each ride.
Contact Support
Powered by Zendesk
