Excluding Workouts from Personal Records
Sometimes you may want to exclude a workout from your personal records. Maybe a friend was trying out your account, or your speed magnet moved out of place and your power readings were wrong. Whatever the reason may be, excluding workouts is easy.
How to Exclude a Ride from Your Records
There is a tab called 'Bests' that shows the records for each interval under each workout in your Career. Under all of that data, there is a button labeled, "Exclude from Personal Records".
Once you click that, a window will pop up asking if you'd like to exclude the workout or start off fresh by excluding all workouts which will reset all of your personal records.
It might take a couple minutes to process, but the workout will now be excluded from your personal records.
Contact Support
Powered by Zendesk
