Device Relay
Device Relay rebroadcasts speed, cadence, and power over ANT+ so you can get the cycling data you want on your cycling computer or head unit.
Device Relay Works With the Following Devices:
  • ANT+ power meters and devices
  • Bluetooth Smart devices like the Wahoo Kickr and Kinetic InRide
  • Non-ANT+ devices CycleOps 300, 400 and Powerbeam Pro
  • Computrainers
Using Device Relay
1. Enable Device Relay on the Devices tab.
2. Once Device Relay is broadcasting, search for a device on your cycling computer or head unit.
3. Connect your devices on your cycling computer or head unit.
The steps for this differ for each cycling computer, but it usually involves going into settings and searching for a power meter. You can verify that the correct power meter is paired by matching the DeviceID to the one displayed in TrainerRoad.
Contact Support
Powered by Zendesk
