Power Spikes
Getting some crazy high power numbers? Here's how to fix it.
Alleviating Power Spikes (VirtualPower)
The primary cause of power spikes while using VirtualPower is a misaligned speed sensor. Since VirtualPower is derived from speed readings, anything affecting speed readings will also affect VirtualPower readings.
Sometimes a rider's speed sensor or speed sensor magnet can be jostled out of position. The speed sensor will send erroneous, very high speed readings to TrainerRoad if the speed sensor is touching or "clipping" the magnet. To solve this problem, simply reposition the speed sensor and magnet.
Alleviating Power Spikes (Power Meter/Electronic Trainer)
Make sure your power meter or electronic trainer has been calibrated properly.
Still have a problem?
Don't hesitate to contact our support staff at support@trainerroad.com if you continue to experience power spikes after troubleshooting.
Have more questions? Submit a request
Comments
  • Avatar
    kelly scott
    chat
  • Avatar
    kelly scott
    trying to fix a problem with my computrainer
  • Avatar
    kelly scott
    no help today I guess?
  • Avatar
    Larry Sussman
    Hi Kelly, I just sent you an email, so hopefully we can get things sorted out for you through that medium. :)
  • Avatar
    leon whaanga
    will try next session. power spikes all over the place.
Powered by Zendesk
