Wattbike
The Wattbike is a stationary bike that measures power output. You can learn more about the Wattbike here.
Is the Wattbike compatible with TrainerRoad?
Yes! The Wattbike can connect to TrainerRoad as a power meter via ANT+ or Bluetooth.
Connecting the Wattbike to TrainerRoad
The Wattbike comes with a head unit which broadcasts the data to TrainerRoad. There are two different models of the Wattbike head unit.
  • Model A Monitor- Can broadcast via ANT+ only.  NOTE: Model A Monitor can be upgraded to Model B for £350 if the user sends their old monitor in to WattBike
  • Model B Monitor- Can broadcast via Bluetooth or ANT+.  NOTE: Not all Model B Monitors come standard with Bluetooth.  If you have a non-Bluetooth enabled version, you can upgrade the monitor for £75.  You will need to send monitor to WattBike for this, and unfortunately this service is only available to users in the UK at this time.
The video below will show you how to pair the Wattbike to TrainerRoad. If this doesn't help, take a look at the detailed instructions from Wattbike.
Contact Support
Powered by Zendesk
