Home Search Results
3 results for “Half Distance Triathlon”
Found 3 results
What are Masters Triathlon Plans?
Masters Triathlon plans are alternate versions of the TrainerRoad triathlon plans. These plans are designed to prioritize recovery with a 2:1 ratio of load and recovery weeks. With a Masters Triathlon plan, you’ll get a recovery week every third week, as opposed to every fourth week in a non-Masters plan. How Do Masters Triathlon Plans Work? Masters Triathlon Plans are based on their standard non-Masters Triathlon Plan equivalents. Specifically, Masters Triathlon Plans include the same distribution of workouts each week as the non-Masters Triathlon plans but encompass more frequent rest with a recovery week every third week. This distribution of rest allows your plan to preserve key workouts across all 3 sports, while still facilitating extra recovery throughout the training plan itself. Adding more frequent recovery weeks ensures an ideal distribution of workouts from week to week while affording plenty of extra rest for anyone who needs it. Who are the Masters Triathlon Plans For? When combined with Adaptive Training, Masters Triathlon Plans can provide an optimal training experience for anyone in need of some additional recuperation from their training. While Masters training is typically associated with older athletes, the Masters Triathlon plans are designed for anyone who might need extra time to recover. This plan will be automatically recommended to you if you are older than 50, but we also think that if you have a high-stress job, are a new parent, shift worker, or someone dealing with an irregular sleep routine you might benefit from these plans. How Can I Get a Masters Triathlon Plan? Masters Plans are available for all triathlon Base Build, and Specialty plans. This includes Sprint, Olympic, Half, and Full distance categories. When a Masters plan becomes available for your current Triathlon plan, you will automatically be prompted with a modal to adjust your plan. Alternatively, you can manually add a Masters Triathlon plan to your Calendar via Plan Builder, the TrainerRoad training plan library, or by choosing to switch future phases of your triathlon plan to a Masters version. Adding a Masters Triathlon Plan Through the Masters Triathlon Plan Modal If you are already on a custom Triathlon plan with a Masters equivalent, a Masters plan announcement modal will automatically pop-up once a Masters version is available for your current training plan. If you are following a custom-built plan this modal will include a button giving you the option to switch your current plan to the Masters equivalent. Masters Tri Modal 1.png Screenshot 2023-12-19 at 12.20.04 PM.png This pop-up will only appear once you reach the first week of a new training phase. If you'd like to adjust your training plan sooner, you can follow the directions below to build a new plan with Plan Builder, or manually adjust your current plan by swapping out a training phase, deleting time off, or adding in a new event. In most cases, though, we recommend waiting until you've finished your current training phase before making any adjustments, as this will help avoid disruptions to the plan itself. Mobile Apps How to get a Masters Triathlon Plan through Plan Builder Step 1: Make sure you are on the latest version of the TrainerRoad mobile app. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: Choose Plan Builder. Step 4: Follow Plan Builder's steps until you reach the Schedule step. Step 5: If a Masters version is available a Masters toggle switch will appear on the Schedule step. Toggle this on to build out your triathlon plan with Masters phases. IMG_784958E52A49-1.jpeg Step 6: Finish building your plan. How to get an Individual Masters Triathlon Plan through the TrainerRoad Plan Library Step 1: Make sure you are on the latest version of the TrainerRoad mobile app. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: In the Individual Training Phases section there are Masters options of each triathlon discipline for Base, Build and Specialty phases (below the standard training phases). Simply, choose the Masters triathlon phase type and volume you would like. IMG_EE57803D4BD5-1.jpeg IMG_43E4E9EAC03D-1.jpeg Step 4: Add to your Calendar. How to Change Your Current Triathlon Plan to a Masters Plan Step 1: Make sure you are on the latest version of the TrainerRoad mobile app. Step 2: Select the Calendar tab from the left-hand navigation menu. Step 3: Select the title of your training plan in the upper left corner IMG_3283.PNG Step 4: Select pencil shaped "edit" icon in the lower left corner. IMG_3284.PNG Step 5: Select the Masters toggle and hit 'Update' IMG_3285.PNG Important Notes: Your current training phase will remain unchanged. Only your future training phases will be adjusted to a Masters version. This will also reset any volume changes you’ve made to individual phases in your plan. Desktop Apps How to get a Masters Triathlon Plan through Plan Builder Step 1: Make sure you are on the latest version of the TrainerRoad desktop app. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: Choose Plan Builder. Step 4: Follow Plan Builder's steps until you reach the Schedule step. Step 5: If a Masters version is available a Masters toggle switch will appear on the Schedule step. Toggle this on to build out your triathlon plan with Masters phases. Screenshot 2024-02-13 at 3.08.10 PM.png Step 6: Finish building your plan. How to get an Individual Masters Triathlon Plan through the TrainerRoad Plan Library Step 1: Make sure you are on the latest version of the TrainerRoad desktop app. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: In the Individual Training Phases section, there will be Masters options of each triathlon discipline for Base, Build and Specialty phases. Simply choose the Masters Triathlon phase and volume that you would like to add. Screenshot 2024-02-13 at 3.01.52 PM.png Screenshot 2024-02-13 at 3.05.28 PM.png Step 4: Select 'Add to your Calendar' How to Change Your Current Triathlon Plan Step 1: Make sure you are on the latest version of the TrainerRoad desktop app. Step 2: Select the Calendar tab from the left-hand navigation menu. Step 3: Select the title of your training plan in the upper left corner Screenshot 2024-02-13 at 2.57.37 PM.png Step 4: Select the pencil shaped "edit" icon in the lower left corner, then select the Masters toggle Screenshot 2024-02-13 at 2.58.24 PM.png Step 5: Hit 'Update' Important Notes: Your current training phase will remain unchanged. Only future training phases will be updated to a Masters version. This will also reset any volume changes you’ve made to individual phases in your plan. Web How to get a Masters Triathlon Plan through Plan Builder Step 1: Make sure you are logged in to www.trainerroad.com. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: Choose Plan Builder. Step 4: Follow Plan Builder's steps until you reach the Schedule step. Step 5: If a Masters version is available a Masters toggle switch will appear on the Schedule step. Toggle this on to build your triathlon plan with Masters phases. PB Masters Toggle.png Step 6: Finish building your plan. How to get an Individual Masters Triathlon Plan through the TrainerRoad Plan Library Step 1: Make sure you are logged in to www.trainerroad.com. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: In the Individual Training Phases section there will be Masters options of each triathlon discipline for Base, Build and Specialty phases. Simply choose the Masters triathlon phase and volume you would like to add to your Calendar. Screenshot 2024-02-13 at 3.10.56 PM.png Screenshot 2024-02-13 at 3.12.42 PM.png Step 4: Select 'Add to your Calendar' How to Change Your Current Triathlon Plan to a Masters Plan Step 1: Make sure you are logged in to www.trainerroad.com. Step 2: Select the Calendar tab from the left-hand navigation menu. Step 3: Scroll to the Calendar annotation containing the name of your Triathlon training plan. Screenshot 2024-02-13 at 3.16.44 PM.png Step 4: Select the Masters toggle. Screenshot 2024-02-13 at 3.17.21 PM.png Step 5: Hit 'Update' Important Notes: Your current training phase will remain unchanged. Only future training phases will be updated to a Masters version. This will also reset any volume changes you’ve made to individual phases in your plan. FAQ Why did TrainerRoad create Masters Triathlon Plans? Masters plans have been a long-standing request from our athletes. Our initial release of Masters cycling plans was warmly received, but did not include triathlon plans. This release adds Masters plans for multisport athletes. We believe that Masters Triathlon plans, especially when combined with Adaptive Training, can offer a highly effective training experience for our athletes by prioritizing recovery and encouraging sustainable progress and consistency. I changed to a Masters Triathlon Plan and now I have two recovery weeks in a row. Why? Plan updates are automatically applied following a recovery week, before the start of a new training phase. This is done to avoid losing recovery weeks overall when the plan's structure is modified. Although rare a double rest week may occur when these changes are implemented. If you have any concerns about changes to your training plan, please reach out to [email protected]. How will I know if my Triathlon plan is a Masters Plan? Masters plans can be recognized in your TrainerRoad Calendar by the addition of “Masters” to the plan name. For example, a Mid Volume, Olympic Distance Masters Base plan will display as "Masters Olympic Triathlon Base- Mid Volume". Screenshot 2024-02-13 at 3.25.12 PM.png Can I convert individual Triathlon training phases to Masters versions? Unfortunately, you cannot convert individual Masters phases to Triathlon phases. This is because of the way that the load and recovery weeks in Masters triathlon plans are distributed versus how they are distributed in Non-Masters Triathlon plans. Important Note: when changing to a Masters triathlon plan, all individual phase changes will be reset. Once your plan is set to a Masters version, though, you will then be free to reapply any desired changes to training phase volume or workout schedules. If Masters phases can't be individually swapped, what phases are available via the swap dropdown menus? All Triathlon phase lengths are now standardized. This means that athletes with Masters Triathlon phases will be able to swap between different triathlon discipline types (Sprint, Olympic, Half Distance and Full Distance) for their current Masters training phase. Screenshot 2024-02-13 at 3.19.44 PM.png For example, you can swap a Masters Sprint Build phase for a Masters Olympic Build phase. Why don't Masters Cycling Plans have a 2:1 Load and Recovery schedule? There are many approaches to Masters Training. We’re confident in both approaches we’ve implemented in our Masters plans and feel that each works well for the specific discipline targeted. Like all TrainerRoad features, though, we will continually refine and improve these plans to ensure that training is optimized based on current science. Why can't I change my plan to a Masters Plan? If you aren't able to swap your training plan to a Masters plan or add a Masters plan to your Calendar you might be trying to add a phase or plan that doesn't have a Masters alternative. Master plans are not currently available for Maintenance plans, Time Crunch plans, Polarized plans, or Traditional Base plans.
Choosing Your Training Plan • Last updated on Aug 20, 2026
Choosing the Right Discipline For Your Events
TrainerRoad builds your plan around your A event's selected discipline or type. This guide is here to help you understand what each discipline trains and how to choose a match for your event. Why Event Type Matters Your event type influences: - Which training phases you get (for example, a plan that emphasizes sustained power vs short, punchy power) - Which training zones and workout profiles are emphasized - What fitness you are most prepared to express on event day No discipline is “better” than any others. Each discipline simply trains your body in a different way to prepare for different event demands. The Simple Way to Choose In many cases, the event’s advertised label is enough: - Criterium → Criterium - Time Trial → Time Trial - Cyclocross → Cyclocross - XCO, XCM, Short Track → the matching MTB discipline - Triathlon Event → the matching triathlon discipline It gets trickier when the event label is broad, like Road Race, Gravel, or Gran Fondo. When that happens, use these four factors to identify the dominant effort type your event will demand: 1. Advertised discipline 2. How long you will ride (duration) 3. Climbing profile (how many climbs, how long, how steep) 4. Your goal (race for results vs ride for a steady finish or target time) A helpful reminder: distance alone is not a reliable guide. The same distance can mean very different effort types depending on terrain, surface, and speed. Duration tells you much more about pacing demands. A quick Decision Guide For More Ambiguous Road & Gravel Events Road races: Rolling Road Race vs Climbing Road Race Start here if your event is a mass start road race and you are unsure which road discipline fits. - Rolling Road Race is usually best when the decisive moments are repeated surges, attacks, and short climbs. Think punchy efforts and frequent changes in pace. - Climbing Road Race is usually best when long, sustained climbs are the defining feature. Think sustained climbing power and longer efforts. Helpful shortcut: - If the key climbs are short and punchy, lean Rolling. - If the key climbs are long and sustained, lean Climbing. If you are not sure, pick the discipline that best matches where you expect the hardest efforts to happen. On some courses, long climbs early do not decide the race, and the event can still be ridden like a Rolling Road Race. Long Road Events: Gran Fondo Gran Fondo is the best fit for events where the dominant demand is steady pacing and endurance. - Typical match: long road events where your goal is to finish strong, ride a steady pace, or hit a target time. - Terrain can be flat or mountainous. For most riders, the pacing challenge is still the main limiter once the duration is long enough. Gravel Events Gravel events can be very different, so the best match depends on duration and how the event is raced. - If your event is primarily a long, steady endurance day where pacing is the priority, Gravel is usually the best fit. - If your event is shorter and raced aggressively with frequent surges, you may also consider Rolling Road Race, Climbing Road Race, or Cross Country Marathon, depending on terrain and surface. Helpful shortcut: - Over about 4 hours: Gravel is usually the best starting point because pacing and endurance are critical for most athletes. - Under about 4 hours: Gravel still works well, but a more race-focused discipline(Rolling/Climbing Road Race) can be a good option if the event is punchy and you are racing for position. Time Trials Time Trial discipline is built around steady, controlled efforts against the clock. - Best fit: most TTs, especially flatter courses or those where pacing is steady and continuous - If your TT is unusually punchy or very climb-heavy, Climbing Road Race can be a reasonable alternative, depending on how the effort actually feels on the day. Hill Climbs There is no dedicated hill climb discipline, so match based on climb duration: - Over about 20 to 30 minutes: Time Trial - About 2 to 30 minutes: Climbing Road Race - Under about 2 minutes: Rolling Road Race or Climbing Road Race (choose based on whether the effort is more punchy or more sustained) If you are doing a season of mixed hill climbs, Climbing Road Race is usually the most well-rounded option. Stage Races Stage races are their own category because day-to-day recovery becomes part of the performance demand. Choose the discipline that matches the stage race type you are doing. If your stage race includes mixed stages, pick the discipline that best represents the dominant demands across the event. Off-Road Event Types in TrainerRoad Off-road events vary significantly. The easiest way to pick the right TrainerRoad event type is to match the discipline to the effort you will repeat most often: short surges, sustained hard laps, or long pacing with hard climbs late. Short Track Cross Country (STXC) Pick STXC if your event is: - About 20 to 30 minutes - Very fast and intense with constant accelerations This plan builds repeatable high-intensity efforts and quick recovery between surges. Cross Country Olympic (XCO) Pick XCO if your event is: - About 60 to 100 minutes - Lap-based with repeated climbs and technical features This plan builds the ability to repeat hard efforts near and above threshold across a full race-length effort. Cross Country Marathon (XCM) Pick XCM if your event is: - About 3 to 8 hours - Off-road with meaningful climbing and repeated hard sections This plan builds long endurance and fatigue resistance, while still preparing you for surges and hard climbs late in the race. Cyclocross (CX) Pick Cyclocross if your event is: - About 45 to 70 minutes - Constantly changing pace with repeated bursts, corners, and short run-ups This plan builds repeatable high-intensity efforts and recovery for one-hour racing. Off-Road Triathlon Many off-road tri formats align closely with Olympic distance demands on the bike, even if the bike leg is shorter, because the terrain is more demanding. - Best starting point: Off-Road Triathlon - Only choose Sprint, Half, or Full if the event distances truly match those formats Quick Tie-Breakers - XCO vs XCM: around an hour and very intense, choose XCO. Multi-hour pacing with hard climbs late, choose XCM. - XCM vs Gravel: if it feels like an off-road race with frequent punchy efforts, choose XCM. If it is more about steady pacing for a long day on mixed surface, choose Gravel. Common Exceptions: When A Different Event Might Help You If there is more than one good option, that is normal. Look at your event’s advertised type, expected finish time, and whether you are racing for results or pacing for a finish or target time. Long events where you are racing for results If the event is long but your goal is explicitly competitive and the race is likely to be decided by surges, attacks, and climbs, you may choose a discipline that places more emphasis on variability and intensity. That can be a good choice, but there is a trade-off: - More emphasis on punchy and race-like fitness - Less emphasis on the deepest steady endurance compared to Gran Fondo or Gravel If your main goal is to pace steadily and finish strong, Gran Fondo or Gravel is still usually the best match. longer climbing events or stage races where you will ride a steady pace In these cases It can be smart to pick a Gran Fondo or Gravel plan, to train for smooth steady efforts instead of training to chase and make breaks up a climb. Mixed terrain/discipline race like a stage race or mixed surface event In those cases, pick the discipline that best matches: - The effort type you will spend the most time doing - Will you be holding a steady pace, or chasing and making breaks? - The effort type you most want to improve for your goal An example could be a longer event where you ride Road, Gravel, & Single Track with plenty of elevation gain: - If you intend to hold a steady pace, Gravel would be a good choice. - If you are going to race it, Climbing Road Race or Cross Country Marathon would better fit that intent for most athletes. Between those you would want to pick what you want to improve. Have More Than One A event? A events should be planned at least 8 weeks apart. TrainerRoad will focus the plan around your A events, in order. After each A event, the plan can shift focus toward the next A event. After the final A event, the plan uses your last B event discipline, or your last C event discipline if there is no B event. A events are the strongest drivers of plan focus. Changing Your Event Type In many cases, you can change an event’s discipline. When you do, TrainerRoad may prompt you to update your plan so training matches the new discipline. There are a few situations where changing discipline requires deleting and recreating the event instead, such as switching between cycling and triathlon categories, or switching between stage race and single-day event categories. FAQs How do I Build a Custom Training Plan? You can use the resources below to learn how to build a custom plan and to dig deeper into their structure: - TrainerRoad Plan Builder Over View & Walk Through - Understand the structure & science behind TrainerRoad Plans. How to Choose Which Event to Make My A Event? In most cases, you want your A event to be your primary event for the season. You can learn more here: - How to Add A, B, & C Events to Your Calendar - How to Prioritize Your Races and Build a Seasonal Race Plan I'm not Training For an Event, What can I do? TrainerRoad has many goal-based plan options as well. You can learn about them here. How Should I Choose the Event Intensity? It's helpful to think of the intensity rating of the event as the aspirational pace you want to ride it. Every athlete is different but here is a bit of general guidance: - Recovery - Tempo could be an all-day or repeated-day effort(rest day or easy day during a stage race). - Tempo - Hard could be a race level effort for 3-8 hours. - Hard - All out efforts would be a max level effort for shorter events(1-3 hours)
Choosing Your Training Plan • Last updated on Feb 13, 2026
Swim Drills and RPE Table
In addition to everything you need to get faster on the bike, our Triathlon plans include swim and run workouts. Of course, your swim and run workouts will be done outside of the TrainerRoad application, but this article should help you better understand the recommended drills we assign you in the pool as well as rates of perceived exertion both in the water and on foot. Swim Drills - Back Sculling (BS) - Keep your arms at your sides and point your fingertips back toward your toes as you propel yourself with those familiar figure-eight movements without moving your hands any wider than shoulder width. Video https://www.youtube.com/watch?v=NvkCqpTsvEQ - Bilateral Breathing (BB) - Swim your regular freestyle stroke while breathing during every third stroke forcing yourself to discover and improve your weaker side. If this is challenging & uncoordinated at first, hang in there - your clumsy side will improve with practice. Video https://www.youtube.com/watch?v=DaCbquF5lm0 - Catch-Up (CU) - Your lead arm will remain fully extended in front of you until your working arm completes a full stroke. The working arm now becomes the lead arm and remains fully extended in front of you until your working arm completes its full stroke and "catches up". Video https://www.youtube.com/watch?v=qpczzwoXbyQ - Chest Sculling (CS) - With your chest facing down, bend your elbows and point your fingertips down while keeping your elbows high. Make the same figure-eight patterns with both hands to propel yourself forward, effectively repeating the center of the stroke. - Fastest Average (FA) - Swim each repetition at a pace that is as fast as you can sustain for the entire set, while still being able to complete all the repetitions at the given RPE. Aim to maintain a consistent time for each repetition throughout the set. For example: If doing 4 x 100m freestyle, it would be better to swim 1:20, 1:21, 1:19, 1:20 (with an average pace of 1:20 per 100m) than to swim 1:18, 1:18, 1:20, 1:28 (averaging 1:21 per 100m). - Fingertips & Thumbs (F&T) - During your normal freestyle stroke, keep your elbows high and lightly drag your fingertips across the water as your working arm recovers. Then, as your working hand exits the water on the release, lightly scrape your thumb against your thigh. These two actions can be done individually or combined. This is sometimes referred to as a "fingertip drag" drill. Video https://www.youtube.com/watch?v=36lp6NgDYF0 - Fists (F) - Swim with clenched fists and focus on rotating your shoulders and bending your working elbow during the catch, creating a pull that's nearly as powerful as one done with an open hand. Video https://www.youtube.com/watch?v=HH0TlKA-UFU - Front Sculling (FS) - Stretch your arms out in front of you, fingertips pointed forward, arms no more than shoulder-width apart and use both hands to propel yourself forward by "sculling" in a figure-eight pattern as you simulate the catch over & over. Use a minimal kick and do this with your head up or down. Video https://www.youtube.com/watch?v=o1ex2GbQ9WI - Half Catch-Up (HCU) - This abbreviated catch-up will bring the full catch-up drill closer to your actual freestyle stroke. Instead of waiting until your working arm reaches your lead arm, start pulling with your lead hand a little earlier when your working hand is even with your lead arm's elbow. This is sometimes referred to as an "almost catch-up" drill. Video https://www.youtube.com/watch?v=FRCDgVG9GuM - Kick & Rotate (K&R) - Begin kicking on your side for 3-5 seconds, then rotate onto your belly and "catch up" to your leading arm with the other arm bringing both arms out in front of you. Pull with the arm that was leading as you roll onto your opposite side. Kick for 3-5 seconds on this side, catch up with the other arm, and immediately pull the previously leading arm and rotate to the opposite side. Over time, try to spend only 2 seconds at a time kicking on each side. This is sometimes referred to as a "kick-switch" drill. Video https://www.youtube.com/watch?v=wBE0Dk1BE5s - Kicking (K) - Swim facedown using only your feet to propel you as you breathe just as you would during a freestyle stroke by rolling to the side and turning your head to catch some air. Focus on "pushing" your chest down while keeping your legs & hips up toward the surface as you practice balance & kicking technique. Video https://www.youtube.com/watch?v=l55T3gby54o - Side Kicking (SK) - Swim on your side with your lower arm extended ahead of you and the upper arm resting against your side. Rest your head against your shoulder and look down, keeping your head completely submerged while using only your kick to propel yourself. Rotate your head slightly when inhaling and try to keep your hips & legs high throughout as you swim a full pool length before switching sides. Video https://www.youtube.com/watch?v=J5gfI3SRLQE - Sighting (S) - Instead of turning your head to the side to breathe, raise your head to look forward and "sight" a landmark toward which you'll swim. Breathe just as you would when turning to the side by inhaling before lowering your head, exhaling underwater, and learn to disrupt your stroke as minimally as possible in the process - eventually not at all. Video https://www.youtube.com/watch?v=zNdvm_VLlqc - Single-Arm (SA) - Restrict yourself to one arm’s use for an entire pool length by keeping the opposite arm extended in front of you or at your side (advanced). If necessary, perform these drills using fins until you improve to the point that you can eliminate them. Try to use a moderate kick and normal body positioning, rolling into your working arm. Video https://www.youtube.com/watch?v=6YXOT_HQtjM - Stroke Counting (SC) - Target your stroke efficiency by trying to reduce the number of strokes you use to reach the opposite side of the pool. Count your strokes on your first trip across, then try to reduce the number of strokes during the next 2-3 trips across the pool by taking longer, more powerful pulls, rotating more & gliding a bit longer. This is sometimes referred to as a "distance per stroke" drill. Video https://www.youtube.com/watch?v=g2sxK3Pz6TM Swimming/Running Rate of Perceived Exertion (RPE) Key | | | | | --- | --- | --- | | RPE 2 | Recovery | Active Recovery | | RPE 4 | Easy | Warmup/Cooldown | | RPE 6 | Easy-Moderate | TR Endurance | | RPE 7 | Moderate | TR Sustained Power | | RPE 8 | Moderate-Hard | TR Threshold | | RPE 9 | Hard | TR VO2max | | RPE 10 | All-Out | TR High Power | | RPE N/A | Sprint | TR Burst Power | Select the following link for more information on the RPE Table: Swimming/Running RPE Key Explained Getting Your Swim Workout to the Pool Looking to bring your swim workouts with you, but don't want to get your phone wet? Here is our suggestion: - Simply write down your swim workout for the day or copy and paste the workout and drill instructions into a document that can be printed. - Next, go ahead and place your workout in a plastic baggie for safekeeping. - When you get to the pool, you can then stick your workout on a kickboard for easy reference during your session. No phone needed!
Triathlon Training • Last updated on Aug 20, 2026
