Home Search Results
10 results for “Base Traditional”
Found 10 results
Workout Levels
Workout Levels are a metric within TrainerRoad that provide a way to easily compare the difficulty of workouts. Workout levels compare the relative difficulty of workouts within each energy system and training zone. They range from 1 to 10, with 1 representing an easy workout and 10 being a very difficult one. How are Workout Levels calculated? Workout Levels go beyond traditional metrics, like Training Stress Score (TSS) and Intensity Factor (IF). They utilize TrainerRoad AI's data-driven insights and incorporate nuanced factors such as repetition, interval length, and recovery time to quantify the relative difficulty of each TrainerRoad workout. The result is workout difficulty rankings that are based on real-world experience and easy to understand. Workout Levels are unique to TrainerRoad, using a formula derived from machine learning and based on our extensive data set. Where are Workout Levels displayed? The primary Workout Level for a workout is displayed on the workout profile alongside other workout information such as duration, TSS, and IF. You will see the workout level on all TrainerRoad workouts: Screenshot 2026-07-16 at 3.09.40 PM.png Workout Levels on the Calendar You will also see a workouts primary Workout Level in the upper left hand corner below the title of the workout when viewing an individual workout: Screenshot 2026-07-16 at 3.11.31 PM.png Primary Workout Level for an Individual Workout Note: The only structured workouts without Workout Levels are FTP assessments and custom workouts. When viewing a TrainerRoad workout you will also see the other Workout Levels targeted in any given workout in the Workout Levels chart below AI Predicted Difficulty. These levels show the performance targets for that particular workout relative to your current FTP: Screenshot 2026-07-16 at 3.18.07 PM.png FAQ How are these different from my individual Athlete Levels? Your individual Athlete Levels are a representation of your capabilities within the context of Workout Levels. Workout Levels are ML-driven quantifications of the relative difficulty workouts. Athlete Levels show your relative current abilities across Training Zones. You can check your Athlete Levels in your Career in the relative zone to check what difficulty of workouts are right for you based on your current abilities. Are Workout Levels always comparable? While Workout Levels do give you a good sense of how a workout might compare relative to another workout in TrainerRoad, Workout Levels are not strictly comparable even within one zone. How a workout feels to you can vary from one workout to the next based on the overall structure and duration of the workout. For this reason we recommend using AI Predicted Difficulty alongside Workout Levels for more insight into how your planned training might feel. Are Workout Levels personalized to each athlete? No. Workout Levels are assigned to a specific workout based on its difficulty and are calculated regardless of an athlete's abilities. Individual Athlete Levels are unique to each athlete. Your Progression Levels give you an indication of what workout difficulty you will be capable of completing. Will my custom workouts have Workout Levels? No, custom workouts do not currently have Workout Levels. Will Outside Workouts have Workout Levels? Yes. Every Outside Workout in the TrainerRoad workout library will have Workout Levels assigned to them. If you find an Outside Workout that doesn't have Workout Levels, please contact [email protected]
TrainerRoad AI • Last updated on Jul 16, 2026
What are Masters Triathlon Plans?
Masters Triathlon plans are alternate versions of the TrainerRoad triathlon plans. These plans are designed to prioritize recovery with a 2:1 ratio of load and recovery weeks. With a Masters Triathlon plan, you’ll get a recovery week every third week, as opposed to every fourth week in a non-Masters plan. How Do Masters Triathlon Plans Work? Masters Triathlon Plans are based on their standard non-Masters Triathlon Plan equivalents. Specifically, Masters Triathlon Plans include the same distribution of workouts each week as the non-Masters Triathlon plans but encompass more frequent rest with a recovery week every third week. This distribution of rest allows your plan to preserve key workouts across all 3 sports, while still facilitating extra recovery throughout the training plan itself. Adding more frequent recovery weeks ensures an ideal distribution of workouts from week to week while affording plenty of extra rest for anyone who needs it. Who are the Masters Triathlon Plans For? When combined with Adaptive Training, Masters Triathlon Plans can provide an optimal training experience for anyone in need of some additional recuperation from their training. While Masters training is typically associated with older athletes, the Masters Triathlon plans are designed for anyone who might need extra time to recover. This plan will be automatically recommended to you if you are older than 50, but we also think that if you have a high-stress job, are a new parent, shift worker, or someone dealing with an irregular sleep routine you might benefit from these plans. How Can I Get a Masters Triathlon Plan? Masters Plans are available for all triathlon Base Build, and Specialty plans. This includes Sprint, Olympic, Half, and Full distance categories. When a Masters plan becomes available for your current Triathlon plan, you will automatically be prompted with a modal to adjust your plan. Alternatively, you can manually add a Masters Triathlon plan to your Calendar via Plan Builder, the TrainerRoad training plan library, or by choosing to switch future phases of your triathlon plan to a Masters version. Adding a Masters Triathlon Plan Through the Masters Triathlon Plan Modal If you are already on a custom Triathlon plan with a Masters equivalent, a Masters plan announcement modal will automatically pop-up once a Masters version is available for your current training plan. If you are following a custom-built plan this modal will include a button giving you the option to switch your current plan to the Masters equivalent. Masters Tri Modal 1.png Screenshot 2023-12-19 at 12.20.04 PM.png This pop-up will only appear once you reach the first week of a new training phase. If you'd like to adjust your training plan sooner, you can follow the directions below to build a new plan with Plan Builder, or manually adjust your current plan by swapping out a training phase, deleting time off, or adding in a new event. In most cases, though, we recommend waiting until you've finished your current training phase before making any adjustments, as this will help avoid disruptions to the plan itself. Mobile Apps How to get a Masters Triathlon Plan through Plan Builder Step 1: Make sure you are on the latest version of the TrainerRoad mobile app. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: Choose Plan Builder. Step 4: Follow Plan Builder's steps until you reach the Schedule step. Step 5: If a Masters version is available a Masters toggle switch will appear on the Schedule step. Toggle this on to build out your triathlon plan with Masters phases. IMG_784958E52A49-1.jpeg Step 6: Finish building your plan. How to get an Individual Masters Triathlon Plan through the TrainerRoad Plan Library Step 1: Make sure you are on the latest version of the TrainerRoad mobile app. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: In the Individual Training Phases section there are Masters options of each triathlon discipline for Base, Build and Specialty phases (below the standard training phases). Simply, choose the Masters triathlon phase type and volume you would like. IMG_EE57803D4BD5-1.jpeg IMG_43E4E9EAC03D-1.jpeg Step 4: Add to your Calendar. How to Change Your Current Triathlon Plan to a Masters Plan Step 1: Make sure you are on the latest version of the TrainerRoad mobile app. Step 2: Select the Calendar tab from the left-hand navigation menu. Step 3: Select the title of your training plan in the upper left corner IMG_3283.PNG Step 4: Select pencil shaped "edit" icon in the lower left corner. IMG_3284.PNG Step 5: Select the Masters toggle and hit 'Update' IMG_3285.PNG Important Notes: Your current training phase will remain unchanged. Only your future training phases will be adjusted to a Masters version. This will also reset any volume changes you’ve made to individual phases in your plan. Desktop Apps How to get a Masters Triathlon Plan through Plan Builder Step 1: Make sure you are on the latest version of the TrainerRoad desktop app. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: Choose Plan Builder. Step 4: Follow Plan Builder's steps until you reach the Schedule step. Step 5: If a Masters version is available a Masters toggle switch will appear on the Schedule step. Toggle this on to build out your triathlon plan with Masters phases. Screenshot 2024-02-13 at 3.08.10 PM.png Step 6: Finish building your plan. How to get an Individual Masters Triathlon Plan through the TrainerRoad Plan Library Step 1: Make sure you are on the latest version of the TrainerRoad desktop app. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: In the Individual Training Phases section, there will be Masters options of each triathlon discipline for Base, Build and Specialty phases. Simply choose the Masters Triathlon phase and volume that you would like to add. Screenshot 2024-02-13 at 3.01.52 PM.png Screenshot 2024-02-13 at 3.05.28 PM.png Step 4: Select 'Add to your Calendar' How to Change Your Current Triathlon Plan Step 1: Make sure you are on the latest version of the TrainerRoad desktop app. Step 2: Select the Calendar tab from the left-hand navigation menu. Step 3: Select the title of your training plan in the upper left corner Screenshot 2024-02-13 at 2.57.37 PM.png Step 4: Select the pencil shaped "edit" icon in the lower left corner, then select the Masters toggle Screenshot 2024-02-13 at 2.58.24 PM.png Step 5: Hit 'Update' Important Notes: Your current training phase will remain unchanged. Only future training phases will be updated to a Masters version. This will also reset any volume changes you’ve made to individual phases in your plan. Web How to get a Masters Triathlon Plan through Plan Builder Step 1: Make sure you are logged in to www.trainerroad.com. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: Choose Plan Builder. Step 4: Follow Plan Builder's steps until you reach the Schedule step. Step 5: If a Masters version is available a Masters toggle switch will appear on the Schedule step. Toggle this on to build your triathlon plan with Masters phases. PB Masters Toggle.png Step 6: Finish building your plan. How to get an Individual Masters Triathlon Plan through the TrainerRoad Plan Library Step 1: Make sure you are logged in to www.trainerroad.com. Step 2: Select the Training Plans tab from the left-hand navigation menu. Step 3: In the Individual Training Phases section there will be Masters options of each triathlon discipline for Base, Build and Specialty phases. Simply choose the Masters triathlon phase and volume you would like to add to your Calendar. Screenshot 2024-02-13 at 3.10.56 PM.png Screenshot 2024-02-13 at 3.12.42 PM.png Step 4: Select 'Add to your Calendar' How to Change Your Current Triathlon Plan to a Masters Plan Step 1: Make sure you are logged in to www.trainerroad.com. Step 2: Select the Calendar tab from the left-hand navigation menu. Step 3: Scroll to the Calendar annotation containing the name of your Triathlon training plan. Screenshot 2024-02-13 at 3.16.44 PM.png Step 4: Select the Masters toggle. Screenshot 2024-02-13 at 3.17.21 PM.png Step 5: Hit 'Update' Important Notes: Your current training phase will remain unchanged. Only future training phases will be updated to a Masters version. This will also reset any volume changes you’ve made to individual phases in your plan. FAQ Why did TrainerRoad create Masters Triathlon Plans? Masters plans have been a long-standing request from our athletes. Our initial release of Masters cycling plans was warmly received, but did not include triathlon plans. This release adds Masters plans for multisport athletes. We believe that Masters Triathlon plans, especially when combined with Adaptive Training, can offer a highly effective training experience for our athletes by prioritizing recovery and encouraging sustainable progress and consistency. I changed to a Masters Triathlon Plan and now I have two recovery weeks in a row. Why? Plan updates are automatically applied following a recovery week, before the start of a new training phase. This is done to avoid losing recovery weeks overall when the plan's structure is modified. Although rare a double rest week may occur when these changes are implemented. If you have any concerns about changes to your training plan, please reach out to [email protected]. How will I know if my Triathlon plan is a Masters Plan? Masters plans can be recognized in your TrainerRoad Calendar by the addition of “Masters” to the plan name. For example, a Mid Volume, Olympic Distance Masters Base plan will display as "Masters Olympic Triathlon Base- Mid Volume". Screenshot 2024-02-13 at 3.25.12 PM.png Can I convert individual Triathlon training phases to Masters versions? Unfortunately, you cannot convert individual Masters phases to Triathlon phases. This is because of the way that the load and recovery weeks in Masters triathlon plans are distributed versus how they are distributed in Non-Masters Triathlon plans. Important Note: when changing to a Masters triathlon plan, all individual phase changes will be reset. Once your plan is set to a Masters version, though, you will then be free to reapply any desired changes to training phase volume or workout schedules. If Masters phases can't be individually swapped, what phases are available via the swap dropdown menus? All Triathlon phase lengths are now standardized. This means that athletes with Masters Triathlon phases will be able to swap between different triathlon discipline types (Sprint, Olympic, Half Distance and Full Distance) for their current Masters training phase. Screenshot 2024-02-13 at 3.19.44 PM.png For example, you can swap a Masters Sprint Build phase for a Masters Olympic Build phase. Why don't Masters Cycling Plans have a 2:1 Load and Recovery schedule? There are many approaches to Masters Training. We’re confident in both approaches we’ve implemented in our Masters plans and feel that each works well for the specific discipline targeted. Like all TrainerRoad features, though, we will continually refine and improve these plans to ensure that training is optimized based on current science. Why can't I change my plan to a Masters Plan? If you aren't able to swap your training plan to a Masters plan or add a Masters plan to your Calendar you might be trying to add a phase or plan that doesn't have a Masters alternative. Master plans are not currently available for Maintenance plans, Time Crunch plans, Polarized plans, or Traditional Base plans.
Choosing Your Training Plan • Last updated on Aug 20, 2026
Plan Builder Overview
Plan Builder is a tool that creates custom plans tailored to you and your goals. Plan Builder considers the unique demands of your goals, your available training time, and your recent training history to build a plan specific to you. Screen Shot 2024-09-16 at 1.02.29 PM.png With Plan Builder, training plans exist for just about every cycling discipline and can account for the specific needs of individual athletes. Build your custom plan and get training right away! Note: The most up to date Plan Builder is only available on the TrainerRoad website! We recommend building your custom plan on the TrainerRoad website to gain access to all of Plan Builders new functionality Plan Builder Walk-Through Plan Builder takes you through a series of steps to build you a fully tailored custom training plan. In Plan Builder, you add a start date, set goals and events for your schedule, choose how you would like to approach your training and customize your plan schedule. After Plan Builder builds your plan you’ll have the option to review it before adding your new plan to you Calendar. Customizing your plan is super easy, so let’s jump into it! Step 1: Sync Your Training History If you have any activity history, Plan Builder can use that data to help shape your plan. You can sync your activity history from Garmin Connect or Strava. If you don’t have any training history coming into TrainerRoad, don’t worry. Your plan will adjust as you progress through your workouts. How to Sync All of Your Garmin Connect Activities 1. Log into TrainerRoad to access your Account Profile. 2. Select “Activity Sync” from the menu on the left-hand side of the screen. 3. Click the option to “Connect with Garmin.” 4. Authorize TrainerRoad to access your Garmin Connect account by selecting “Agree & Connect.” 5. In Garmin Connect, authorize TrainerRoad to access your Garmin Connect account and data. If you would like a more detailed walkthrough, check out this article: Garmin Connect How to Sync All of Your Strava Activities 1. Log into TrainerRoad to access your Account Profile. 2. Select "Activity Sync" from the menu on the left-hand side of the screen. 3. Under Strava, click "Connect." 4. Read through how the TrainerRoad-Strava integration works and click "Agree & Connect." 5. Enter your Strava login credentials. 6. Authorize TR to connect with your Strava account. If you would like a more detailed walkthrough, check out this article: Strava Step 2: Choose your Goal and Start Date First you will need to let Plan Builder know if you are training to prepare for a specific event or if you would like a training plan to train for a general fitness goal. Screen Shot 2025-03-27 at 8.03.19 AM.png Once you have done this you will be prompted to choose the start date of your plan. You can start a plan at any time in the future, as long as plans do not have overlapping start/end dates with other plans. Screen Shot 2024-09-12 at 3.56.44 PM.png Step 3: Add Events or Goals Once you have chosen your start date you'll be adding your events or choosing your main goal and discipline! Select the options below for more information on adding events or choosing a goal and discipline. To Prepare for an Event This is where you will add your goal events! These can be cycling events and cycling stage races. Events can be added at these three different priority levels: - A Events are your most important events of the season. Your training plan is designed to have you at your best for these events. As such, you can only have a few A events in a year. These events have a full taper before the event with a recovery week after. A events should ideally be 12 weeks apart in order to be in peak form for both. - B Events can be seasonal objectives in their own right. They allow you to try different race prep and strategies to see what works best for you. B events receive a taper in the week of the event. - C Events are great practice and experience, but the outcome of these races should carry little value. C events will not change your plan. You can treat them like a hard workout. Screen Shot 2024-09-12 at 4.25.21 PM.png If you are unsure what races you are doing or what your final schedule is this upcoming season, no worries. You can always add events to your Calendar after your plan has been built and your plan will automatically adapt around the new additions. With that said we recommend adding at least 1 “A” priority event to your plan, when you build your initial training plan. Unsure of how to prioritize your races? Check out this blog article for more information. General Fitness Goals If you've chosen General Fitness Goals first you will be prompted to choose the length of your plan. You can choose between a 1 month, 2 month, and 3 month plan or opt for another duration! Screen Shot 2024-09-16 at 12.40.43 PM.png Once you have done this you will prompted to choose your plan's main focus by selecting your primary training discipline and your training plans primary goal: Screen Shot 2024-09-12 at 4.01.12 PM.png Step 4: Training Approach In the next step you can decide how aggressive you want your training to be by choosing your Training Approach. When choosing your training approach there are five options; conservative, moderate, balanced, demanding, and aggressive: - Conservative - A conservative approach is for athletes looking for more modest gains while benefiting from a reduced training load. This is a great approach for athletes looking to maintain their fitness or who are returning from injury. - Moderate - A moderate approach is for athletes who want steady progress and constant improvements with a comfortable and manageable training load. This is a solid option for athletes who haven’t trained in a long time or are new to the sport. - Balanced - This approach is called balanced because, for most athletes, this is the best approach to progress fitness while receiving enough recovery to remain consistent and prevent long-term fatigue. - Demanding - This is an approach for athletes who are prepared for a demanding plan and who understand their recovery needs to make progress. - Aggressive - This is an approach for athletes who want to push the boundaries of their current limits. Athletes will need to have a solid understanding of their nutrition, hydration, rest, and recovery needs for this training approach. Screen Shot 2024-09-12 at 4.29.51 PM.png Be sure to read the descriptions of each option on the slider. When in doubt we recommend opting for a more balanced approach! Once you've generated your schedule you'll be able to view your training plan! Step 5: Schedule Screen Shot 2024-09-12 at 4.39.48 PM.png Here in the schedule step, Plan Builder will automatically recommend a training schedule based on your training approach and imported training data. You will see an outline of what a general training week will look like. You can customize your schedule in the training week outline in these five ways: Dragging and dropping workouts: You can drag and drop workouts in the weekly schedule to the days of the week that you would prefer to complete them! workout move test.png Note: If you drag two workouts so they are close together you may receive a warning. Be sure to give yourself enough recovery between workouts! Changing the duration: You can change the duration of your planned workouts using the time drop down for each workout. Screen Shot 2024-09-12 at 4.44.24 PM.png Changing the workout type: You can change your indoor structured workouts to TrainerRoad Outside Workouts, Group Rides or Solo Rides, and Zwift Race from the drop-down menu. Screenshot 2025-06-09 at 10.32.31 AM.png Screenshot 2025-06-09 at 10.33.11 AM.png Adjusting amount of workouts per week: To adjust the amount of workouts per week or the number of intense workouts per week go ahead and click on the settings icon located in the top right hand corner of the weekly schedule. Screen Shot 2024-09-12 at 4.40.21 PM.png From here you can adjust how many days per week you want to train and how many intense workouts you want per week. Screen Shot 2024-09-12 at 5.12.32 PM.png Keep in mind, if you choose to do more days of training you may receive a warning that your plan has too much training load. You can restore the plan to the original settings to get you back on track by selecting Restore Schedule. Screen Shot 2024-09-12 at 5.01.59 PM.png If you'd like to tinker you can also reduce the duration of workouts, or change how many intense days you have per week to get your desired training schedule. Restoring your Original Schedule If at any point you'd like to restore your plan back to the initial recommendation go ahead and select the Restore option located to the right of the settings button and then hit Restore Schedule: Screen Shot 2024-09-12 at 4.55.29 PM.png Screen Shot 2024-09-12 at 4.58.40 PM.png Step 6: Name your plan and Review! Finally you can go ahead and give your training plan a name, and take the plan to review! Screen Shot 2024-09-12 at 5.04.53 PM.png You will see a breakdown of your custom training plan with details of your schedule and an overview of your plan phases and when they start, before you add the plan to your Calendar Screen Shot 2024-09-12 at 5.06.36 PM.png Your plan will be composed of these three different phases: - Base Training Phase is where it all begins. It's the foundation of cycling and triathlon success, developing resilient aerobic fitness and laying the groundwork for higher-intensity, discipline-specific training later on. The importance of base training can't be overstated. - Build Training Phase builds discipline-specific fitness on your aerobic foundation, pushing you out of your comfort zone to increase your sustainable workload and make you faster. - Specialty Training Phase Focuses your training on the specific demands of your goals and/or events. This is a demanding discipline-specific final block of training. FAQ What if I already have events on my calendar? Plan Builder will detect events already on your calendar, and ask you to "Include" them once you reach the “Events” step of the process. What if I need to add events later? No problem! When new events are added after a custom plan has been added to the calendar, we’ll ask you if you would like those events to be accounted for in your plan and edit the plan to better fit that event. What if I need to take time off? You can add time at any point in your TrainerRoad Calendar once your plan is built. Learn how here: How to Add Time Off to My TrainerRoad Calendar What if I’ve already started training? Go ahead and choose a start date when you actually started training, even though it's in the past. This will make the plan automatically start where you were in your training! Why does my plan go Base/Build/Base? In your plan, when you have extra time before your goal event, alternating between Base and Build phases ensures your body stays responsive and well-prepared for your target event. Utilizing the Base phase after building fitness allows you to reduce fatigue, prevent plateaus, and enter your Specialty phase with the energy needed to maximize your event-specific gains. TrainerRoad Base training is not the same as Traditional Base training. So when TrainerRoad Base training is used after a Build phase, it does not revert the plan to significantly easier Z1/Z2 training. Instead, it strategically shifts your training to maintain progression while giving your body the necessary preparation for the final push into the Specialty phase. Note: If your plan is long enough, alternating between Base and Build serves the same preparatory function mentioned above. I got a different volume than what I’ve been doing, why is that? Your recommendation is customized for you based on your current capabilities as an athlete, your goal, and your Training Approach. If you are seeing a different volume than what you have been doing you might’ve been doing too much volume before, or not enough. Why did my long Endurance ride change to a Solo Ride? We recommend doing particularly long Sunday Endurance rides outside. You’ll notice that your training plan’s Solo Ride still has wattage/RPE targets and instructions on how to ride so that you can maintain the same goals as your scheduled workout. How do you know which training plan and schedule is best for me? We do a deep analysis of all of your data to intelligently recommend how much volume, intensity, and recovery you need. Where are Masters plans? Masters plans are training plans with one less day of intensity per week. You can adjust how many intense days per week your training schedule has. To do this open the Settings panel to change between 2- and 3-days of intensity per week. Masters should use 2-intense workout plans. Can I adjust the total amount of workouts per week? You can adjust how many workouts per week your training schedule has. To do this open the Settings panel to change between 2-6 workouts per week. We highly suggest using our customized training schedule recommendation, though. How can I make a plan for maintaining fitness? When you start building a plan, you will be asked if you want to build a plan for an event or fitness goals. If you would like to build a plan to maintain fitness, select fitness goals, then select your discipline and choose “Maintaining Fitness” as your goal. This will build a plan focused on maintaining your specific level of fitness. Can I make workouts too long or too short? If you edit your plan in a way that would be detrimental to your fitness goals, or ability to complete the plan, you’ll see a Warning banner on the page. This means your plan schedule is not recommended. Changing workout durations to be shorter than the initial recommendation, isn’t necessarily a bad thing, but you may be able to handle more than you think! I'm not trying to win races, but I do want to get into better shape. Is there a plan for that? Yes! Plan Builder can build plans structured around your primary discipline and goals. How does the PBv2 work for athletes who don’t have a target event? Plan Builder can build plans structured around your primary discipline and goals. How do I balance my strength training and other activities with my TrainerRoad Plan? Does Plan Builder consider strength training or cross-training? If you don’t have Activity Sync set up with TrainerRoad, we recommend getting that set up so that all of your training, strength training included, is imported to TrainerRoad. If you do anything that would lead to long-term burnout, TrainerRoad AI will adjust your TrainerRoad workouts down or prescribe a Rest Day. Will my current training plan change with the update? You’ll see the option to optimize your current custom plan if you have one added to your Calendar. You can always update your Training Approach and Training Schedule by clicking on the plan name or plan annotation from your Calendar. How can I update my plan if my goals or schedule change? You’ll see the option to optimize your current custom plan if you have one. You can always update your Training Approach and Training Schedule by clicking on the plan name or plan annotation from your Calendar. Where can I use the new Plan Builder? You can use the new Plan Builder on the TrainerRoad website! Can I use Plan Builder if I have limited time to train? Yes! You can even make plans with only 2 workouts per week. You can adjust the duration of any workout to be shorter if you want. Will Plan Builder re-build the plan if I add new events after the plan has started? Yes! Plan Builder will adjust around any event added to your Calendar. Can I still choose specific training phases (Base, Build, Specialty) manually? Yes! You can still add individual training phases to your Calendar. To add individual Training phases to your Calendar select Training Phases at the Training Plans page. I'm training for an event but I don't know the exact dates yet. What should I do? If you aren’t sure what the exact dates of your priority events are you have a couple of options! Add the event to your plan with an approximate date of when it may be. Once you know the date, update the event date on your Calendar and we’ll ask to update your plan to peak your fitness for your event. Build a plan without an event, selecting the event’s discipline and your personal goal. Once you know the date, add the event to your Calendar and we’ll update your plan to peak your fitness for your event. Are Triathlon plans supported? You can build a training plan with Plan Builder! There are some differences in the steps when you build a triathlon plan with Plan Builder instead of a cycling plan. Can I make a Polarized plan with the new Plan Builder? Currently you cannot build a Polarized Plan Builder plan. The good news is that this is something we are hoping to implement in the future.
Plan Builder • Last updated on Jul 21, 2026
Base/Build/Specialty Overview
Traditional Periodization Every TrainerRoad training plan has been designed around what’s known as traditional periodization. Traditional periodization divides your season into distinct phases with the purpose of dedicating each phase to specific goals. By following a logical pattern, each phase ultimately leads to a specific set of adaptations upon which achieving peak fitness is hinged. Base Phase Proper strength and endurance building begins with a foundation. Just like you wouldn’t build a house without a foundation, you wouldn’t build your higher-level endurance and power without establishing a foundation of strength and aerobic endurance first. Your first step in the training plan process is to establish that foundation in what’s known as the Base Phase. Build Phase The Build Phase of TrainerRoad’s training plans cranks the volume up a notch. Based on the demands of your specific performance goals, we focus on your short power, sustained power or varying mixes of the two. By focusing on your muscular endurance and/or maximal aerobic power, our aim is to develop and improve those higher-level forms of fitness mentioned earlier. Specialty Phase The Specialty Phase strives to be as specific to your target event and performance goals as possible. Whether you’re a road racer, triathlete, off-road rider or enthusiast, the Specialty Phase serves to refine the fitness you’ve developed over the previous weeks of training. By fine-tuning your fitness and mechanics, this phase of training will have you peaked, ultimately fresh and specifically prepared for race day.
Understanding your Training Plans • Last updated on Aug 13, 2026
The Basics of Base Training
Principles: The purpose of base training is to establish a foundation of fitness that will allow cyclists to build towards their physiological potential for a goal event. It may seem counterintuitive to revert to base training every year after reaching new heights of performance, but this strategy pays dividends come race season. Much like a pyramid, our fitness is built in a hierarchical fashion, with the initial work serving as a critical foundation that will eventually support a higher peak. This foundation is achieved through effective base training in which cyclists raise their fitness levels. During this phase there are various transformations happening on different levels, but for the sake of simplicity, we’ll just focus on the efficiency of muscles to transform energy into speed on the bike. As you focus your training on developing your aerobic capacity, amongst other useful adaptations, you train your body to become more efficient at turning fat into energy and producing energy aerobically regardless of its fuel. This transformation takes place within the mitochondria (the powerhouses of the cell ) in your muscles. So, as you spend more time stressing your aerobic energy system, your body adapts by creating more efficient mitochondria. This adaptation will benefit you throughout all portions of your power curve because mitochondria are involved in turning energy into speed at all different intensities. Takeaway: By following a Base training plan, you will establish fundamental aspects of your fitness capabilities. The primary focus is on aerobic endurance, muscular endurance, and form/speed/power capabilities. TrainerRoad Base Plans: General, Traditional, Polarized, and Masters So it's time for base, but you aren't sure what will work best for you... what do you do? You can use the guide below to decide which Base plan is right for you. General Base This take on Base training integrates a bit more variety than the Traditional approach. You will see a lot of Sweet Spot work, but the plan also contains VO2 max intervals and neuromuscular bursts in the Low and Mid-Volume Plans. The reasoning behind this is that most amateur athletes when training at a low-intensity will run out of time in their schedules before they really tax their endurance muscles to the limit. Through Sweet Spot work, and a mix of higher intensity work, you can attain sufficient training stress to initiate adaptation in your limited training time. - When choosing a Base plan, we've found General Base (GB) is the best choice for most athletes who don't have enough time (less than 10 hours/week) to complete a full Traditional Base. If that's you, we recommend trying one of our General Base plans to fit your schedule. - This plan initiates general fitness gains much faster (can expect FTP increase in 6-8 weeks) Learn more in our blog post: What is General Base Training? Traditional Base The Traditional Base approach requires long, low-intensity hours in the saddle. There are a few key demographics that this approach is best for: - Those recovering from injury will benefit from the gentle approach of Traditional Base - Athletes who have large amounts of time before their target events. By planning their season well in advance of their race days, riders afford themselves the option of cultivating a wider base of fitness. Completing Traditional Base prior to a General Base circuit is one way to build this huge, substantial base. Polarized Base Polarized Training spits your training into two intensities at specific volumes: ≈80% low intensity, 20% high intensity or 95/5%. This structure takes more time in the saddle to generate comparable adaptations to General Base, but less than Traditional Base. Polarized training is best for: - Experienced athletes with a strong aerobic base who can handle intense sessions. - Athletes who have the time and want to train with long endurance sessions and hard high-intensity efforts. Masters Base Masters Base plans are designed to prioritize recovery with no more than two days of Sweet Spot, or higher-intensity workouts each week. These plans work well for: - These plans are made for athlete's who need more recovery time. - Any athlete who needs more recovery time will find these plans extremely beneficial, not just masters athletes. - They can be used for athletes returning to interval training after extended time off, injury, or illness. Learn more about Masters Plans from this article: What are Masters Plans? Takeaway: For most applications, General or Masters Base is the way to go. Relevant Podcasts [13:45] Podcast 068: Sweet Spot vs Traditional Base discussion Can I Skip Base Training? Typically, we do not recommend athletes skip any training phases. You will get the fastest if you work through all three training phases in order and to completion before moving onto your next phase of training. However, every rider has different time constraints, as well as different levels of fitness and cycling backgrounds going into their structured training. Here are a few common reasons that athletes want to skip Base: - Riders with heavily experienced backgrounds who are familiar with the level of base training they have at that point in the season. These riders can decide to bypass or reduce the duration of the Base phase, and move straight into a Build phase if they have been doing structured Base outside of TrainerRoad. - Riders with mid-level or minimal experience, whose target event is less than 28 weeks away (the time it takes to complete Base/Build/Specialty). We’d suggest s/he complete the entire Base phase of training and move as far along through the Build and Specialty training plans as time will allow. See our article "Not Enough Time!" To further explore how you should structure your season with less than 28 weeks. - Riders who are mid-season and have already peaked for en event, but have 16 or fewer weeks until their next event. These athletes should first consider a low-intensity training block but can absolutely skip base and jump back into Build. This is what we call a 'rebuild' and you can learn more about how to structure around this in our "Peaking for Multiple 'A' Races" article. Takeaway: No, you should probably not skip Base Phase, however there are a few fringe cases where it is an acceptable decision. Base Training Q&A Q: Time constraints aside, how many hours per week would I need to spend base training in order to improve upon last season's fitness? A: The goal is to increase your annual training volume by 5% but not more than 15% over last year’s training volume in order to improve upon last year’s performance without overdoing it. Q: Do I really have to go this easy during Base I? It doesn't seem like I'm working hard enough to gain any training benefit. A: Properly performed, Aerobic Endurance rides (roughly 60-80% FTP) train your type IIb fibers - which are the most versatile muscle fiber type - to prefer fat over sugar, one of the key objectives of Base Training. This adaptation is negatively affected if you work too hard, so go slow so your body learns to metabolize fat and spare sugar at low, but eventually greater, effort levels. Q: Sometimes I don't have the time for the prescribed ride duration. How can I address these time constraints without missing out on the benefits of base training? A: Although athletes competing in events requiring long hours on the bike need to adapt to long rides with no breaks, riding twice daily is often the only way to log high daily base mileage and is also an excellent way to reduce body fat during Base Training. Simply break your longer rides into 2 segments and perform them at the beginning, middle and/or end of your day. Try to refrain from breaking your long weekend ride into halves, and avoid breaking rides less than 90 minutes into smaller parts whenever possible. Q: Are recovery weeks really necessary when the training intensity is already so low? A: Yes. Regardless of the low intensity, the body needs time to absorb new stress before additional stress is applied, even if that stress isn't due to high-intensity intervals or race efforts. Recovery weeks will simply drop the stress to roughly half the stress of your current phase's toughest week but keep you on the bike the same number of times in order to avoid any disruption of your training schedule. Also, there’s no reason (nor benefit) to exceed 50% FTP during Recovery Weeks unless you are certain that riding over 50% FTP is still regenerative and restful and allows your body to recover and prep for the next, more stressful, block of training. Q: Which drills should I be doing per session and how many do I do for the duration? A: The drills are briefly during the workouts themselves. As long as you haven't checked the "Hide text during workout" box on the Profile tab, and the onscreen directions will prompt you to add particular drills at particular times.
Understanding your Training Plans • Last updated on Aug 20, 2026
Athlete Levels
Athlete Levels are a dynamic, real-time representation of your fitness and ability to express your FTP across each training zone. They are measured on a scale from 1-10 to track your progress. Screenshot 2026-01-21 at 9.47.30 AM.png As you complete rides, TrainerRoad AI analyzes and adjusts these levels based on the relative difficulty of your workouts in each zone, as well as how successful you were in completing them. Where are Athlete Levels displayed? You can find your up to date Athlete levels on the Career page in the TrainerRoad website and the TrainerRoad app. Screenshot 2026-01-21 at 9.45.35 AM.png FAQs Why did my Athlete Levels change? - Completing Workouts Athlete Levels are determined by the level of recent workouts an athlete has completed in that power zone and how successfully they completed these workouts. If your performance warrants an adjustment to your Athlete Level, this will happen once the ride is completed and saved. - FTP Increase Athlete Levels automatically adjust downwards after an FTP increase. This is because two factors affect the difficulty of a workout: your FTP and the Workout Level. If either of these factors increases, the scheduled workout gets harder and vice versa. By reducing your Athlete Levels (and in turn, upcoming Workout Levels) we can offset the sudden increase in workout difficulty traditionally associated with FTP increases. As a result, we can more accurately serve you the right workouts for your current capabilities, to keep your training on track and ramp the difficulty of your workouts at a sustainable rate. - Time Off Your capabilities decline when you take time off the bike or don't train specific skills for extended periods. To reflect this, your Athlete Levels gradually adjust after time off, or after long periods without completed workouts in any individual training zone. The magnitude of these time-related adjustments varies from Level-to-Level because changes in different types of fitness occur at different rates. Why did my Athlete Levels stay the same after my FTP Decreased? Your FTP decreasing will result in easier workouts in itself since the power targets will be reduced. That means your Athlete Levels will not be reduced unless you continue to struggle with workouts at your new FTP. If you think you're capable of a more challenging workout than what's scheduled, you can use Workout Alternates to find a more difficult workout. TrainerRoad AI will adjust your future training based on your performance. Why didn't my Athlete Levels Change after Completing a Workout? Not every workout will change your Athlete Levels! If you complete a workout at or below your current level, and stuck to the power targets, you won't see an Athlete Level change.
TrainerRoad AI • Last updated on Jan 21, 2026
Masters plans are an alternate version offered for most TrainerRoad training plans. These alternate plans are designed to prioritize recovery with no more than two days of higher-intensity workouts per week. These plans are designed for any athlete seeking additional recovery in their training. How do Masters Plans Work? Masters Plans cycling are based on the standard non-masters TrainerRoad training plans. They utilize the standard plans' structure and volume. Opposed to their counterparts which have three intense workouts per week they have no more than two days of higher-intensity workouts each week. Tuesday and Saturday workouts will typically remain unchanged in the masters plan in comparison to the non-master versions. In some cases, however, these days might be slightly rearranged to prioritize the most important stimulus. This helps ensure that the workouts are structured to achieve the plan’s goal. How Can I Get a Masters Plan? Masters Plans are available for most cycling and triathlon Base, Build, and Specialty plans. You can opt to make your entire training plan a Masters Plan when you build out your custom plan with plan Builder or you can add individual phases as Masters phases directly to your Calendar. You can do this on the website as well as the TR app. To do this follow these steps: How to get a Masters Plan through Plan Builder Step One: Select the Training Plans tab from the left-hand navigation menu. Step Two: Choose Plan Builder. Step Three: Follow Plan Builders steps until you reach the Training Schedule Step Step Four: Select the Settings Icon in the upper right corner of the weekly schedule. Screenshot 2026-07-21 at 12.20.26 PM.png Step Five: Under intense days per week opt for 2 days (Masters Athletes) and select Apply. Screenshot 2026-07-21 at 12.22.54 PM.png Step Six: Finish building out your training plan with Plan Builder and add it to your Calendar. How to Add Individual Masters Phases Step One: Select the Training Plans tab from the left-hand navigation menu and select View Phases in Training Phases. Screenshot 2026-07-21 at 11.50.52 AM.png Step Two: In the Individual Training Phases section choose your desired phase type (Base, Build, or Specialty) Step Three: In the phase type you have selected, switch on the Masters Plan option in the upper right hand corner to view all the training phases as Masters phases. Screenshot 2026-07-21 at 12.14.33 PM.png Step Four: Select your Desired phase, select Schedule Plan and add the plan with your desired schedule and daily settings to finish. Note: In the final step before scheduling, you can toggle the Masters Plans option on and off to view the difference between the Masters plan and the standard plan. FAQ What standard TrainerRoad plans don't have Masters versions? Master plans are not available for Maintenance plans, Time Crunch plans, Polarized plans, or Traditional Base plans. How will I know if my plan is a Masters Plan? You will know that you are on a masters plan because you will only have two intense workouts scheduled per week. If you have any more than two, this means you are on a standard TrainerRoad plan. Why can't I change my plan to a Masters Plan? If you aren't able to swap your training plan to a Masters plan or add a Masters plan to your Calendar you might be trying to add a phase that doesn't have a Masters alternative. Master plans are not available for Maintenance plans, Time Crunch plans, Polarized plans, or Traditional Base plans.
Choosing Your Training Plan • Last updated on Jul 21, 2026
Ramp Test FAQs
The Ramp Test is our preferred method for getting an effective estimate of Functional Threshold Power: a measure of cycling performance and the metric used to guide all TrainerRoad workouts. To learn more about FTP testing and the Ramp Test, click here. Ramp Test - Frequently Asked Questions How does TrainerRoad calculate my FTP from the Ramp Test? We take 75% of your best one-minute power. If you are above target for the final minute, the app will reduce your result by a small amount. It’s important to follow the target power closely as you progress through your test. How hard should I go during the ramp test? For the most accurate results, give the ramp test everything you've got. At the end of the testing section, you should have nothing left in the tank. I didn’t immediately stop pedaling immediately after I failed the test. Does this affect my FTP calculation? Nope! Your FTP is based on your best one-minute power, not your last one-minute power. So, soft-pedaling or grinding gears after finishing the ramped section will not affect your FTP score in any way. What if I think my score is too high? If you score slightly higher than you expect, we recommend you still keep the Ramp Test result and see how training goes. You might surprise yourself with how much you're able to handle. Our workouts are designed to be pretty challenging, but doable. If you are able to successfully complete the first several workouts using your Ramp Test FTP, you'll know that you're using the correct FTP. That said, if you find that you are unable to complete many of your prescribed workouts, you can go ahead and decrease your FTP in 2-5% increments as needed. What if I think my score is too low? If you score slightly lower than you expect we recommend you still take the Ramp Test result and see how training goes. In particular, pay attention to how you're able to handle threshold work or any VO2 max efforts. If you feel that typically very hard workouts are just too easy, you can always manually adjust your FTP on your Account page. We recommend adjusting in 2-5% increments as needed. If you think your FTP result is much lower than it should be we recommend to check the following: - Did you REALLY dig deep and go hard? - Do you have excessive fatigue going into the test? - Did you have a major power dropout during your Ramp Test? - Were you able to achieve a level of performance similar to recent PRs? - Did you follow the target power closely? - Remember, the app will reduce your result by a small amount if you are above target for the final minute I’m a steady-state athlete (TT or triathlon). Should I do the Ramp Test or is the 20-minute test a better assessment for me? We recommend the Ramp test. Even though the intensity of the effort required during the final steps of a Ramp Test is well above the intensity required during a longer, lower-intensity effort, the information gleaned from the ramp protocol is more accurate than an FTP estimate based on a poorly paced 8- or 20-minute test. With a sufficient level of commitment and freshness, this format leaves little room for error in cyclists of all disciplines. I went into the test fatigued and got a low score. I thought the new test is less dependent on fatigue? While the new test may take less time and may exact a smaller physiological toll on the athlete, it is not any easier. You need to be reasonably recovered and prepared for any assessment workout in order to obtain usable results. Can/should I do the Ramp Test more often than the 8/20 minute tests? We still recommend assessing every 4-6 weeks. If you’ve taken more than 3-4 weeks off from training, resume training following an FTP assessment. Do you still have the old 8 and 20-minute tests? Yes! The 8 minute and 20-minute tests aren’t going anywhere, and you can still use them if you prefer them. Can I increase the warmup? We don't recommend increasing the warmup, but it can be done if necessary. Due to the very low-intensity nature of the warmup and the fact that it’s scaled to your previous or predicted FTP, this assessment incorporates a sufficient warm-up period that will adequately prepare riders for the higher-intensity steps that will close the ramp assessment. If, however, you’d prefer to add a few extra minutes of warmup time prior to beginning the Ramp Test, do so every time you perform a Ramp Test in order to keep the results and protocol consistent. Should I do this test in ERG mode? If you have a smart trainer we recommend that you do the test in ERG mode (default). A smart trainer is not required and those doing the test in ERG mode do not have an advantage over individuals on a traditional trainer. What is a good ride to do after the Ramp test to keep my TSS® in line with the 8/20 minute tests? It’s not required to do a workout after the Ramp Test. But for riders who want to get a little work in, we recommend actively recovering for 10-15 minutes followed by one of these workouts: - Carter - Birch - West Vidette - Pettit - Homers Nose - Bald Knob Why can't I find the Ramp Test in the app? Make sure that your app is up to date. The Ramp Test is not available on some older versions of the TrainerRoad. If it's still not showing up, check to see if there are filters enabled that might be hiding the app from your workouts list. Note: The Ramp Test is not available in our Legacy app. Legacy users will need to continue using the 8- and 20-minute FTP tests. If you have any questions about this, please contact our support team at [email protected].
General Usage FAQs • Last updated on Aug 13, 2026
Training in ROUVY with TrainerRoad: FAQs
Workout Availability and Access What workouts will appear in ROUVY? If you are following a plan, your indoor TrainerRoad workouts scheduled for today will automatically appear in ROUVY. Workouts will not be sent to ROUVY on your plan’s scheduled rest days. If you aren't following a plan, a recommended workout of the day will automatically appear in ROUVY when you open up the app. Where do I find my workouts in ROUVY? Today’s workout appears near the top of the ROUVY app “Home” screen, as well as prominently near the top of the “Workouts” page.  What if my workout doesn't appear in ROUVY? First, check that it is scheduled for today, as workouts scheduled on future days aren’t synced until the day they are scheduled. Any changes in TrainerRoad may take a few minutes to appear in ROUVY. What happens to removed calendar workouts? Workouts removed from your TrainerRoad calendar will also disappear from ROUVY. This might not always happen immediately. Will planned runs sync over to ROUVY?  No, only planned indoor cycling workouts will sync to ROUVY.  FTP and Power Settings Will my TrainerRoad FTP sync to ROUVY? No. While workout targets are based on your TrainerRoad FTP, you'll need to manually update your FTP in ROUVY to match. This only affects the color-coding of workout blocks in ROUVY, not their actual power targets. Will my ROUVY ride count for AI FTP Detection? Yes, TrainerRoad workouts completed in ROUVY count toward AI FTP Detection. Does the sync affect my Progression Levels? Yes, workouts completed in ROUVY will update your TrainerRoad Progression Levels just like regular TrainerRoad workouts. Training in ROUVY Can I still do ERG mode workouts in ROUVY? Yes, though ERG behavior may feel slightly different than in TrainerRoad. Does drafting affect ERG mode workouts? Drafting other riders in ROUVY should have no impact on your ERG workouts. Can I use ERG mode with route resistance? No, ROUVY’s structured workout mode disables terrain resistance. Toggling ERG off in ROUVY during a workout switches to a steady resistance mode that is not impacted by terrain. Can I extend workout segments in ROUVY? No. You can’t extend your warmup and cool down in ROUVY like you do in TrainerRoad. When your structured workout ends, your workout does, too. If you’d like to ride more we recommend starting a new ROUVY activity immediately after your workout. Can I adjust the warmup/cooldown intensity? Yes! ROUVY limits intensity adjustments to 150% of the original target power, though. For higher intensities, you can exit ERG mode and shift into harder gears. What if I want to continue riding after my workout? You can’t keep riding in the same ROUVY activity after completing the structured portion. If you’d like to ride more we recommend starting a new ROUVY activity immediately after your workout. What if I complete my chosen route in ROUVY before finishing my TrainerRoad workout? If you ride to the finish of your selected route before your workout is complete, you'll automatically restart the route. Your workout will not be cut short. Post-Workout and Syncing When will my ROUVY ride appear in TrainerRoad? Rides typically sync within a few minutes. You may need to refresh the TrainerRoad app to see the completed workout. How do surveys work with ROUVY? You'll receive a survey prompt in ROUVY right after completing your workout. You can also complete the survey through the TrainerRoad app. What if I toggle RPE surveys off in ROUVY? If you click "Don't show this again" on the ROUVY postworkout RPE survey screen, you'll no longer receive the survey after your workout in ROUVY. We don't recommend doing this, because your RPE response is very important for TrainerRoad AI to optimize your training. If you do toggle them off, they can be reenabled later from the "General" section of the ROUVY app settings menu. You can also always update your survey response later by clicking the completed workout within TrainerRoad. What appears in Strava after a ROUVY workout? The activity will appear as "ROUVY - [TR Workout title]". You can edit this title in Strava without affecting the TrainerRoad sync. Will my workout visualization look different in TrainerRoad? Yes, completed ROUVY workouts show the map and elevation data rather than TrainerRoad's traditional workout profile. How do I see my workout details in TrainerRoad after completing it in ROUVY? From the calendar, click the workout name in the TrainerRoad Workout box to view the original workout description and details. What appears in my TrainerRoad calendar? Occasionally, for a few moments after completing your workout, you may see both the ROUVY activity and planned TrainerRoad workout. These will merge automatically. How do I know if a workout synced successfully? For planned workouts, the ROUVY icon will appear in the workout’s footer on your TrainerRoad calendar once it’s successfully been pushed on the day it is scheduled. The completed workout will appear in your TrainerRoad calendar with "ROUVY" noted as the source.  Additional Features Will workout instructions appear in ROUVY? Yes, for workouts that include instructions in TrainerRoad. You can check if a workout has instructions on its detail page or disable them entirely through TrainerRoad app settings. Do I need both apps open during workouts? No, you only need ROUVY running to complete your workout. TrainerRoad doesn't need to be open. Do I need to download TrainerRoad to complete workouts in ROUVY? Nope. You don’t need the TrainerRoad app to complete workouts in ROUVY. If you want to make adjustments to your TrainerRoad training plan, build a new plan, or adjust your TrainerRoad settings you can do all of these things from the website. Will outside workouts sync to ROUVY? No, only indoor versions of workouts will sync to ROUVY.  Will group rides and other calendar items sync to ROUVY? No, only structured TrainerRoad workouts will appear in ROUVY.
General Usage • Last updated on Sep 28, 2026
Training in Zwift with TrainerRoad: FAQ
Workout Availability and Access What workouts will appear in Zwift? If you are following a plan your indoor TrainerRoad workouts scheduled for today will automatically appear in Zwift. If you aren't following a plan, a recommended workout of the day will automatically appear in Zwift when you open up the app. Where do I find my workouts in Zwift? Today's workout appears in the "For You" section of the Zwift app. What if my workout doesn't appear in Zwift? First check that it is scheduled within the next two days. Any changes in TrainerRoad may take a few minutes to appear in Zwift. What happens to removed calendar workouts? Workouts removed from your TrainerRoad calendar will disappear from Zwift within about a day of their originally scheduled date. Will planned runs sync over to Zwift? No, only planned indoor cycling workouts will sync to Zwift. FTP and Power Settings Will my TrainerRoad FTP sync to Zwift? No. While workout targets are based on your TrainerRoad FTP, you'll need to manually update your FTP in Zwift to match. This only affects the color-coding of workout blocks in Zwift. Will my Zwift ride count for AI FTP Detection? Yes, TrainerRoad workouts completed in Zwift count toward both your initial 10 required workouts and ongoing AI FTP Detection. Does the sync affect my Progression Levels? Yes, workouts completed in Zwift will update your TrainerRoad Progression Levels just like regular TrainerRoad workouts. Training in Zwift Can I still do ERG mode workouts in Zwift? Yes, though ERG behavior may feel slightly different than in TrainerRoad. Power targets are rounded to the nearest watt rather than the nearest 5 watts. How does drafting affect ERG mode workouts? You may notice small power fluctuations from drafting effects. This is normal Zwift behavior and won't significantly impact your training. Why does power ramp up slower in Zwift compared to TrainerRoad? Zwift's power transitions are more gradual than TrainerRoad's. This is normal and won't significantly impact your workout quality. Can I use ERG mode with route resistance? No, Zwift's structured workout mode disables terrain resistance. For endurance rides wanting terrain feedback, consider using Zwift's pace partners instead. Can I control ERG mode through the Companion app? Yes, you can toggle ERG mode on and off and adjust intensity using the Zwift Companion app during workouts. What if I lose connection during a workout? If you experience a dropout, try adjusting the intensity +/- and then returning to 100% to reestablish ERG mode. What if I need to pause during a workout? You can pause your workout in Zwift! You can do this through the app as well as the companion app. Can I extend workout segments in Zwift? You won't be able to extend your warmup and cool down like you do in TR, but you can free-ride before starting the workout for additional warm-up and continue riding after for a longer cooldown. Can I adjust the warmup/cooldown intensity? Yes! Zwift limits intensity adjustments to 125% of the target power, though. For higher intensities, you can exit ERG mode and ride in incline mode. What if I want to continue riding after my workout? You can keep riding after completing the structured portion. The entire activity will sync back to TrainerRoad as one ride. Post-Workout and Syncing When will my Zwift ride appear in TrainerRoad? Rides typically sync within a few minutes. You may need to refresh the TrainerRoad app to see the completed workout. How do surveys work with Zwift? You'll receive a survey prompt in Zwift right after completing your workout. You can also complete the survey through the TrainerRoad app. What appears in Strava after a Zwift workout? The activity will appear as "Zwift - TrainerRoad: [workout] in [world]". You can edit this title in Strava without affecting the TrainerRoad sync. Will my workout visualization look different in TrainerRoad? Yes, completed Zwift workouts show the map and elevation data rather than TrainerRoad's traditional workout profile. How do I see my workout details in TrainerRoad after completing it in Zwift? From the calendar, click the workout name in the Source Workout box to view the original workout description and details. What appears in my TrainerRoad calendar? Initially, you may see both the Zwift activity and TrainerRoad workout. These will merge automatically, though it may take a few moments after completing the post-workout survey. How do I know if a workout synced successfully? The workout will appear in your TrainerRoad calendar with "Zwift" noted as the source. A survey prompt will appear once sync is complete. Additional Features How do I access the TrainerRoad kit in Zwift? The kit becomes available in your garage once you connect your TrainerRoad account. Check out the steps in this article here for more info on your Zwift kit: Does TrainerRoad have a Club in Zwift? Yes! We will hold regular group rides and community events and would love for you to join. You can do that here: TrainerRoad Zwift Club Can I use Zwift's route badges during workouts? Yes, you can select any route while completing your TrainerRoad workout to earn route badges and XP. Will workout instructions appear in Zwift? Yes, for workouts that include instructions in TrainerRoad. You can check if a workout has instructions on its detail page or disable them entirely through TrainerRoad app settings. Do I need both apps open during workouts? No, you only need Zwift running to complete your workout. TrainerRoad doesn't need to be open. Do I need to download TrainerRoad to complete workouts in Zwift? Nope. You don’t need the TrainerRoad app to complete workouts in Zwift. If you want to make adjustments to your TrainerRoad training plan, build a new plan, or adjust your TrainerRoad settings you can do all of these things from the website. Will outside workouts sync to Zwift? No, only indoor versions of workouts will sync to Zwift. Will group rides and other calendar items sync to Zwift? No, only structured TrainerRoad workouts will appear in Zwift.
Activity Sync • Last updated on Jun 04, 2026
