Testing Frequency
How Often Should I Reassess My FTP?
Typically, FTP tests are standardized throughout training plans every six weeks.
If you aren't using one of TrainerRoad's structured training plans, if you're using your own plan, or if the plan you're using doesn't include regular FTP assessments, you should still schedule your FTP assessments about every six weeks or so.
It takes the body about this long to absorb training stress, i.e. adapt physiologically to consistent stress, therefore six weeks seems to be the best amount of time between tests.
Any more often than this and you might not see any sort of measurable change; any less often and you might be under-challenging yourself with power levels that don't match your improved fitness.
When Should I Raise My FTP?
That's a good question and the answer is: it depends.
Our cyclocross training plans will increase the demands of each week's workouts so that you don't have to increase your FTP, but will instead increase the duration of your intervals and then use the monthly time trials to less-formally measure improvement in FTP.
Most plans, however, assume that you're routinely assessing FTP so that each subsequent 6-8 weeks of training is based on your most recent FTP. Accordingly, assessment workouts are scheduled throughout these plans as that day's workout.
Testing
At TrainerRoad, one way to generate your FTP is to reassess every 6-8 weeks.  The nice thing about repeating a structured assessment protocol is that it's repeatable and you can control the variables. It's not only easy to see a bump in average power over your 20 minute or 8 minute test but our software will automatically calculate and update your FTP.
Intervals
Personally, I like to raise my FTP based on the power I can routinely sustain in my longer interval workouts.
For example, if I do a 2x20-minute workout at FTP it should feel pretty hard, but if I get through the workout without digging too deeply then I'll consider raising my FTP by 5 watts after the workout. Then, over the course of the next workout I see how I feel make small adjustments from there, if necessary.
I prefer this method because I'm constantly pushing my FTP and making the workouts more demanding and more productive.
On the other side of this coin, if I find I can't complete my more intense workouts with this recently increased FTP then I might drop those 5 watts off again.
The idea is to keep pushing and challenging myself while still completing the workouts.
Combine the Two
Ideally, you'll utilize some combination of the two above techniques as this is probably the most thorough way to measure progress. With both, you'll constantly be pushing yourself in addition to having repeatable, measurable tests to get some hard numbers.
Have more questions? Submit a request
Comments
  • Avatar
    Matthew Polaine
    There is another aspect to frequency of testing - having an off day, or even week. Few of us can devote all our time to training, and we have to juggle work/family/DIY/finance etc. I have often retaken a scheduled FTP test a week later because the prior one was on 'a bad day'.
    Sometimes the boss being an arse can boost aggression and performance, but being ground down by petty bureaucracy can leave one reaching for the TV remote and a beer instead of a ride. Your FTP measurement will be affected, as it will by being tired, having a slight cold or just missing one's mojo.
    I Rubber Glove test about once a month, because it is also a workout, but because if I come under my prior FTP I still leave it at my PB setting. If I manage to improve it, then I change it, so that my FTP is always being ramped up through the season. I reset this in January/February.
  • Avatar
    Jamie Wallis
    Hi team, I have recently switched over to a Powertap G3 but left my Virtual FTP the same and didn't re-test. Last night I attempted Donna (3x12min intervals at close to FTP) and it kicked my butt and I barely hung on for 1 interval.
    I am doing the mid volume sweet spot base 2 and im at the end of week 2, so have a little residual fatigue in the legs.
    Is there a general guide or rule to follow in a way that I can knock down the wattage without impacting the training plan, or will I need to completely freshen up and then re-test? Thanks for your help.
Powered by Zendesk
