Wahoo KICKR SNAP Pairing Process
The Wahoo KICKR SNAP is the wheel-on version of Wahoo's original KICKR. Similar to the KICKR, the KICKR SNAP uses both ANT+ and Bluetooth Smart to communicate with TrainerRoad for the ultimate indoor-training experience.
New KICKR SNAP users will want to check out Wahoo's article on getting their trainer ready to ride.
Wahoo KICKR SNAP
Paring your KICKR SNAP to your iOS Device
1. Open the TrainerRoad app and go to the Devices screen.
Make sure your phone has either Bluetooth or ANT+ enabled.
Note that you will need the Wahoo ANT+ Key and possibly the Apple 30-pin to lightning adapter in order to enable ANT+ on iOS devices. Learn more about ANT+ connectivity.
2. Tap the KICKR SNAP option to initiate the pairing process.
Once paired, the grey square on the right will turn green.
3. Tap the KICKR SNAP once more to open the Device Settings screen.
From here, you can perform a spindown calibration, rename the device, select the mode, and specify PowerMatch options.
4. Perform a Spindown Calibration. Tap "Calibration" in the Device Settings screen.
It is recommended that you perform the spindown after spinning for 5-10 minutes to allow you tire to warm up.
If you receive an error message following the spindown calibration, try adjusting the tension on the tire. An error message may indicate too much or too little tension on your rear tire.
Pairing the Wahoo KICKR (Android)
Make sure that either Bluetooth or ANT+ is enabled and your KICKR is plugged in and awake.
2. Tap the KICKR option to initiate the pairing process.
3. Tap the KICKR once more to open the Device Settings screen.
Pairing the Wahoo KICKR Snap to Desktop
1. Open the TrainerRoad app and go to the Devices screen.  Make sure either ANT+ or Bluetooth is turned on.
2. Search for the Wahoo KICKR and click on it to pair.  The device box will be highlighted green one pairing is successful.
Bluetooth: You will need a BLED112 USB dongle to pair via Bluetooth on PC.  For Mac, you can pair directly using the computer's built in Bluetooth.  Learn more about Bluetooth connectivity
ANT+: You will need a ANT+ USB 2 stick in order to use TrainerRoad's automatic resistance control feature. Learn more about ANT+ connectivity.
3. Click the KICKR once more to open the Device Settings screen.
5. Now you're ready to ride!
Pairing the Wahoo KICKR SNAP to the TrainerRoad Legacy App
Via ANT+
Note: Pair the KICKR SNAP as a "Wahoo KICKR ANT+" to the desktop application.
1. Open the TrainerRoad app and go to the Devices tab. Make sure your ANT+ USB stick is plugged into your computer.
Note that you will need a ANT+ USB 2 stick in order to use TrainerRoad's automatic resistance control feature. Learn more about ANT+ connectivity.
If you don't have an ANT+ stick plugged in, you'll see this:
2. Once your ANT+ stick is in, click "Search for ANT+ USB" and you'll see a list of devices you can pair with.
Scroll toward the bottom of this list and you'll see the option to pair your KICKR SNAP.
3. Click the Pair button next the Wahoo KICKR SNAP.
Make sure that your KICKR SNAP is plugged into a power outlet. In order for TrainerRoad to read the KICKR SNAP, you may need to get on the bike and begin pedaling to wake the KICKR SNAP up.
 4. Your KICKR SNAP is now paired.
5. Click the Spindown button, and follow the instructions to perform a spindown calibration.
This will ensure your KICKR SNAP's readings are accurate.
via Bluetooth Smart (4.0)
Note: Pair the KICKR SNAP as a "Wahoo KICKR" to the desktop application.
Learn more about Bluetooth Smart connectivity.
1. Open the TrainerRoad app, and go to the Devices tab.
2. Scroll to the Bluetooth Smart Device section, and find the Wahoo KICKR SNAP.
3. Click the Pair button, and wait for the KICKR SNAP to connect with TrainerRoad.
4. Click the Spindown button, and follow the instructions to perform a spindown calibration.
How does the KICKR SNAP work with TrainerRoad during test workouts?
TrainerRoad will automatically switch the KICKR SNAP from Erg mode into Level mode during the test intervals (20 or 8 minute periods) of a test workout. We do this because we don't want the app to control your KICKR SNAP and put limitations on how hard you can ride!
TrainerRoad will control your KICKR SNAP throughout the warm up, ensuring that you're well prepared for the test(s), but will switch modes once the test starts. Level mode allows you to shift gears to find the optimal cadence for your test and will help you achieve the highest wattage average possible.
What do I do if it is very difficult to pedal in Level mode?
You'll want to be in a small gear when you start your test. If you start in your biggest gear when the KICKR SNAP switches to level it's like being in your biggest gear on a very steep hill.
Make sure that you shift down before the testing period starts.
Why am I still unable to pair my KICKR SNAP via ANT+ or Bluetooth 4.0?
If you're still unable to pair after following these steps, it's likely that you will need to upgrade your KICKR SNAP's firmware. You will need an iOS device (iPhone or iPad) and the Wahoo Utility app to do so. If you're still experiencing issues, shoot our support team a message at support@trainerroad.com.
Contact Support
Powered by Zendesk
