TriDot
Connecting TrainerRoad to your TriDot account is easy! Setting up a connection with TriDot through TrainerRoad Activity Sync allows completed TrainerRoad workouts to be synced to your TriDot account and TriDot workouts to be synced to your TrainerRoad Calendar.
Note: Only workouts completed after the sync is enabled will sync across.
How to Sync TrainerRoad and TriDot
To do this, you'll need to set up your Ride Sync preferences via your Online Profile.
1. Log into your TrainerRoad account online to access your Account Profile page.
2. Select "Connections" from the menu on the left-hand side of the screen.
3. Scroll down to find TriDot and click "Connect."
4. Read about the integration and click "Agree & Connect."
5. Log into TriDot.
6. Click "Authorize."
7. TriDot and TrainerRoad are now connected!
Troubleshooting
If you're having trouble syncing rides to or from TriDot, you can try disconnecting and re-connecting TriDot entirely.
Just go to the Activity Sync page and select "Disconnect". If you're asked to keep or delete data, select "Keep".
If you're still running into trouble, reach out to our support team here and we're more than happy to help!
    0 out of 0 found this helpful
