Skip to content
Home Search Results
2 results for “Prioritizing Races A B C Races”
Found 2 results
How to Add A, B, and C Events to Your Calendar
A key component of any training plan is knowing when your events are going to take place and how you are going to prioritize them. With Calendar, you can add events at any time and TrainerRoad will adapt your plan accordingly. What Types of Events Are There? Before adding any events to your Calendar it’s first important to know the different classifications of events. As athletes, races are often very important to us. For many, it's the whole reason we train, and in an ideal world, we would roll up to each race with the ability to perform at our maximum physical potential. However, the reality is that the human body cannot maintain the optimal conditions required to perform at its absolute peak for very long. "Peaking", as we call it, requires an optimal balance of fitness and freshness, and these "stars align" for only a brief window. Through the use of our Training Plans, you'll be able to plan your season so that the "stars align" on the day that your performance is most important to you. The first step of Building your season is Event & Race Prioritization. The terminology we use for this is A, B, and C races. Below, we’ll explain how each of these types of races will fit into your season. A Race - These will be races that you will perform at your absolute peak fitness and should be events that are the most important to you. It is best to have around one or two "A" races per year. - If you have multiple A races, they should be at least 12 weeks apart in order to be in peak form for both. If you have two A races within 12 weeks of each other, we recommend prioritizing one as an A race and the other as a B race. - "A" races often have two-week tapers leading up to them, which call for a reduction in overall Training Stress resulting in an increase in freshness, all while maintaining fitness to create this elusive "Peak.” B Races - While you won’t be fully peaked for these, B races will be excellent trials of your fitness, and you can still be very competitive in them. Keep in mind that your competitors are restricted by the same human limitations as you are, so while you can’t always be in your absolute peak form, they can’t either. - While these races can be season objectives in their own right, they mostly allow you extra opportunities to try different race/nutrition strategies to see what works for you and your body. - These races can be particularly important because they build mental racing experience and confidence that you can carry into your higher-priority "A" events. - You will be given the option to add opener workouts in the days leading up to their B race when adding events using Plan Builder. C Races - These races are strictly for practice, experience, and fun. The outcomes should carry much less emotional value, and as such, you will simply "train through" them. They should hold a similar value as a key hard workout. - Keep in mind that structured work is what makes you faster, not simply riding hard all the time, and recovery is just as important. - Since these are essentially viewed as a form of training, no taper is required, and if possible, you should schedule them in the same manner as which you’d find a really tough workout, i.e., following an easy or off day. Takeaway: You can't perform at your peak physical fitness forever, so it is important to decide when you want to be your fastest and plan accordingly. How Event Priority Affects Adaptations - A Events - TrainerRoad will add a taper for the event and an opener workout the day before the event (if you've enabled this option in the Plan Builder flow). - B Events - TrainerRoad will add an opener workout the day before the event (if you've enabled this option in the Plan Builder flow). - C Events - These events are essentially training/workouts, no taper is involved so TrainerRoad will remove any scheduled workouts on this day. For more on how to prioritize your events to build a training plan, check out this Article: - How to Prioritize Your Races and Build a Seasonal Race Plan Adding an Event to the Calendar 1. To add a Race/Event to your calendar, either click on the specific day that your event will take place, or the "+ Add" button on the top right part of your screen. 2. Select "Event" from the drawer on the right of the screen. 3. Enter the pertinent information regarding the event, such as whether it's an A, B, or C event, its duration, and intensity, etc. 4. Once the event is added, you'll be prompted to adapt your plan to include the event. Select "Adapt". Editing an Existing Event in the Calendar To edit an Event, simply select it from the Calendar to open the dialogue box then click the Edit/Pencil icon. To simply move the event, you can also drag and drop the event from one day to another if, for example, it was rescheduled. After editing your Event adaptations will be prompted based on A, B & C Events prioritization. Marking an Event Complete If you import an outside ride file on the day of your event, it will automatically match that activity to the event and mark it as complete. In case that doesn't happen automatically you can also associate your event's ride file manually (see Match a Planned Workout with a Completed Workout/Ride). If you don't have a ride file for your event, you can also manually mark the event as complete by clicking on the event from the Calendar and selecting Mark as Complete. Add an Event in Plan Builder You can use Plan Builder if you'd like to build a training plan leading up to a specific event as well as add multiple events during the Plan Builder flow. To learn more about how to use Plan Builder check out this article: - Plan Builder Overview For more information on A, B, and C, races and how to prioritize them, check out the resources below! Podcast Discussion: [13:20] Podcast 134: How to Prioritize your races [31:30] Podcast 134: A, B, and C Race Definitions Further education: Peaking for Multiple "A" Races Not Enough Time Too Much Time! Related Training Articles: Peak on Race Day: 5 Questions to Plan Your Perfect Season
Your Plan & Calendar
Plan Builder FAQs
If you don't see the answer to your Plan Builder question down below, please reach out to [email protected] for more information on Plan Builder. General What is Plan Builder - Plan Builder creates a custom training plan that brings you to peak fitness for your goal event or discipline. Plan Builder takes into consideration your goals, how much you want to train and when, all of the events on your training calendar, and the demands of your goal event to give you a truly customized training experience. Why Plan Builder? - Plan Builder accounts for all of the unique variations in your training schedule, event schedule and lifestyle that might affect the progression of your training plan. By adjusting your training plan in accordance with your needs your plan will be easier to follow and ultimately more effective. Where Do I Start? - If you don’t have a training plan, you can jump straight into Plan Builder. 1. To start constructing your custom training plan, first, go to your online career. 2. Select the Training Plans tab in the navigation menu on the left-hand side of the screen. 3. Select Build Create My Custom Plan to launch Plan Builder. Screen Shot 2025-01-16 at 11.30.13 AM.png Is Plan Builder available in the TrainerRoad app? - Athletes can build their custom Plan Builder plans via the desktop apps or the TrainerRoad Website. With that said, we recommend building your training plan on the website as the website's version of Plan Builder has added functionality. - To use Plan Builder from within the desktop app, make sure you're on the latest app version, then go to the Training Plans section of the app. How Plan Builder Works How did you come up with the recommended training volume? - The recommended training volume is based on your training approach and the amount of training you have completed in the past few weeks of training. I want to start my training plan in the past. Can I do that? - Yes! If you have already started training you can backdate the plan by selecting the date you started training this season. Why didn’t Plan Builder suggest the Base, Build and Specialty phases in order? - It is very rare that your available training time will perfectly align with the length of a Base, Build, and Specialty Phase training progression, so adjustments need to be made. When these adjustments are needed, Plan Builder uses the latest sports science research and millions of training data points to create the ideal training progression to bring you to peak fitness. Why is Plan Builder suggesting I go back to the Base Phase in the middle of my plan? - In many cases, athletes with less experience doing structured interval training benefit most by spending more time in the Base Phase. Additionally, a mid-season return to base training can allow the body to recover from more strenuous forms of training, and reach new heights by entering a base phase with a higher FTP. Why is Plan Builder suggesting I go to a Specialty Phase in the middle of my plan? - Plan Builder strategically uses different training phases to increase fitness and freshness in order to make you as fast as possible for your goal event. In many cases, the Specialty Phase can be a great opportunity for the body to increase freshness without losing fitness. This is particularly true for athletes with a lot of experience doing interval training and serves as a great mid-season reset point for any rider, especially during long training progression Why is Plan Builder suggesting I do more than one Build Phase? - Athletes that have a moderate level of experience with interval training can benefit from more time spent in the Build Phase to fully reach their potential. Doing too many weeks in a row of Build training can be extremely fatiguing, so Plan Builder will split up excessively long Build Phases with a Base or Specialty Phase. Events What if I don’t have any goal events? - No events, no problem! If you aren't training for an event you can build a goal Based training plan. What if I have multiple priority events? - You can add as many C events and B events as you’d like, but A events (priority events) must be spaced eight weeks apart. Anything less than 8 weeks between goal events won’t allow you enough time to recover and rebuild sufficiently to reach peak fitness once again. - If you have two priority events within 8 weeks of each other, evaluate which event is not as important and make one event an A event and the other event a B event. You will still have rest allocated before the B event but you will only have a taper and a peak for the A event. What if my priority event is a multi-day event? - If you are training for a multi-day event, mark your event as a ‘Stage Race’ when you categorize the discipline of your event My stage race includes multiple disciplines. Which should I choose for "targeted discipline" - Mark the event you’d like to prioritize as the targeted discipline. You’ll taper for the entire stage race, but your Specialty training will be geared towards your targeted discipline. What if I already have events on my Calendar? - If you already have events on your TrainerRoad calendar Plan Builder will accommodate these events. If you’d like to start fresh you can delete the current events on your Calendar and add them when you use Plan Builder. For more information on how to delete events check out this help center article: Editing Your Calendar What if I need to add events later on? - New events can be added at any time. If you would like to add additional events to your TrainerRoad Calendar go ahead and check out this help center article: Add A/B/C Priority Events What if my goal event is more than a year away? - Plan Builder will create a training plan for any event within two years of the day you’ll start training. What do you mean by A, B and C Events? - Categorizing your events as A, B and C events is an easy way to prioritize the importance of your events. For more information on prioritizing events go ahead and check out this help center article: Prioritizing Races (A, B & C Races) Do I need an A Event for Plan Builder? - If you plan on racing, at least one of your events should be an A-priority event. If you aren’t sure which event you would like to make your A event check out this help center article on prioritizing events: Prioritizing Races (A, B & C Races) What if I want to train for a whole series of events instead of just one event? - If you are training for an entire series, we still recommend you make one event within that series an A race, and marking the rest as B races. This will allow Plan Builder to bring you to peak fitness. Plan Builder will build in tapers, rest and openers around the existing events, so your training will be kept on track. I don’t know what sort of event my race is. What should I pick? - If you don’t know what sort of event your race is, select the discipline that is closest to the type of event you plan on racing. I am training for a time trial distance other than 40k. Does Plan Builder work for that? - Yes. When creating the event, enter the event duration and intensity and Plan Builder will take care of the rest. Adjusting Your Custom Plan What if I need to take time off? - When you need to take time off you can edit your Calendar to adjust for time spent off the bike. For detailed instructions on how to edit your training plan check out this help center article: Editing Your Calendar What if I have already started training? - You can use Plan Builder even if you are in the middle of a training plan right now. First, you will want to delete your current training plan from your Calendar. For detailed instructions on how to delete a custom training plan check out this help center article: Delete/Unschedule a TrainerRoad Plan - When you add your custom plan to your TrainerRoad Calendar go ahead and choose the day you started training for your current season. When your custom plan is added to your Calendar, it will include the workouts you have already completed this season. How do I start over, clear my calendar, and create a new Plan Builder plan? - If you already have a training plan added to your TrainerRoad Calendar you will want to delete (or unschedule) this training plan before you build your new custom plan. Note that this will only delete planned workouts - any workouts you have completed will be saved. For detailed instructions on how to delete a custom training plan check out this help center article: Delete/Unschedule a TrainerRoad Plan What happens to my current training rides if I delete/unschedule my current training plan? - When you delete your current training plan to add a custom plan all of your completed workouts will remain on your Calendar. What happens to my A/B/C priority events if I delete my new plan? - If you delete a plan created through Plan Builder, any events that you added to your calendar via that plan will remain on your calendar. If you create a new plan, you can add these events to your plan by clicking the "Include" button in the Existing Events section of Plan Builder. Should I take the Ramp Test before I start Plan Builder? - The Ramp Test will automatically be the first workout in any training phase or plan. If you are just starting a TrainerRoad plan, we definitely recommend starting off with this workout. If you have recently completed a Ramp Test in another training plan you can skip this Ramp Test at your own discretion. I don’t have much time until my goal event. Can Plan Builder create a training plan on a short timeline? - Absolutely! Plan Builder will build a training plan for your goal event, as long as you have at least one week until the event. I want to train on different days than Plan Builder suggests. Can I change that? - Definitely. You can customize the schedule of your training week during the "Schedule" section of creating the plan. Simply drag and drop your training days. Can I decide which days I want to train outside? - Yes! When you create the schedule for your training plan you can mark specific days in your training week as outside rides. You can do this one by one, or adjust this per training block when building your custom plan. After your plan is made, you can change any workout to be an outside or inside workout on the fly. Can I change my training volume halfway through my plan? - You can change the number of days in your training plan at any point after Plan Builder has made your custom training plan. To change the training volume of your plan after it has been built, follow these steps: 1. Go to your online career. 2. Select the Calendar tab in the menu on the left-hand side of the screen. 3. Navigate to your current training block, or the block you are about to start. 4. Select the Block on your Calendar: 5. In the menu that appears on the right select 'Edit Weekly Schedule' 6. Adjust your training schedule in the subsequent steps. Can I make changes to my training plan once I’ve added it to my calendar? - Absolutely, your training plan can always be edited. You can add additional events, swap workouts, edit training weeks and even delete workouts. For detailed instructions on how to edit your Calendar go ahead and check out this article: Editing Your Calendar
