Solving WiFi Interference
It's possible for WiFi routers to interfere with your ANT+/Bluetooth devices. ANT+ runs on 2.4 GHz, so interference is likely to occur if your router is also on 2.4 GHz and near your bike setup. Luckily, it's fairly simple to switch your WiFi's channel.
Test it
The check for this is to test your ANT+ or Bluetooth devices with TrainerRoad while the WiFi is turned off. If the device signal improves, then it's probably the WiFi that's the problem.
Change the WiFi Channel
If this helps the problem, then it’s most likely that the wireless channels are clashing with each other. Fortunately, changing the WiFi channel is pretty easy.
 Learn how to change your WiFi channel.
Not the Wifi?
Don't think WiFi is the problem? Check out more articles on connecting devices.
    1 out of 1 found this helpful
