Adding Events to Your Training Plan
You can add new events to your Calendar at any point throughout your training plan. When adding new events past the end date of your training plan you will have have the option to rebuild your plan to include the newly added event or add the event as an unincorporated event.
Adding an Event Past the End Date of a Plan
When you add an event to your Calendar that takes place after the end date of a training plan in progress you will be asked if you would like to add the event to your training plan:
Yes! I want to Add this Event to My Plan
If you'd like to add the new event to your current training plan go ahead and select Yes. Plan Builder will rebuild your training plan with an extended version that ends after the newly added event.
If you change your mind and decide you don't want this event incorporated into your current plan you can always delete the event from your Calendar and Plan Builder will rebuild your plan with the prior end date.
No! I Don't Want to Add this Event to My Plan
If you don’t want to incorporate this event into your current training plan go ahead and select No. Choosing No will give you the option to add the event as a non-incorporated event on your Calendar.
This means your current training plan won’t re-build around this event but you can include it in future training plans if you choose. When you build out your next training plan with Plan Builder, you can incorporate this event into your training plan.
Adding an Event to Your Current Plan
When you add an event to your Calendar that takes place during your current training plan you will be asked whether you would like to Adapt your plan to take the newly added race into account:
If you select Yes your plan will be rebuilt and your race will be added to your Calendar. If you decide you do not want your plan to be rebuilt you can select No the event will be added to your Calendar as an unincorporated event.
    1 out of 1 found this helpful
