Delete/Unschedule a TrainerRoad Plan
Deleting (or unscheduling) a plan is just as easy as adding one! We will not delete any workouts you may have completed in the plan, even if you delete it. Your hard work won't be lost by changing up your schedule.
How to Delete a Plan
A training plan can be removed via the Career page or the Calendar.
Career Page
Navigate to your Career on the web, where you will see an overview of your current plan. From there, select the ellipsis (three-dot menu) and select "Delete Plan".
Calendar
You can also delete the plan from the Calendar.
  1. Select your plan title from the Calendar header, or the "Plan Start" annotation on your Calendar.
    • The plan name is much easier to find in the Calendar header because it displays whatever week of the plan you are viewing.
    • To find the "Plan Start" annotation, you'll need to navigate to the start date of the plan in your Calendar.
  2. Select the Trash Icon from the "Training Plan Overview" drawer.
  3. Select Delete My Plan from the dialogue box.
TSS Chart Phase Annotations
The option of deleting a plan using the same process described above is also available by clicking on the horizontal purple Phase Annotations in the TSS Chart at the top of your Calendar.
    3 out of 17 found this helpful
