Home Search Results
3 results for “Training in Rouvy with Trai”
Found 3 results
Syncing ROUVY with TrainerRoad
You can complete scheduled or recommended TrainerRoad cycling workouts in ROUVY when you connect your ROUVY account to your TrainerRoad account. Here’s how to get the sync between the two platforms set up: How to Connect ROUVY and TrainerRoad You'll establish a connection between the two platforms through the TrainerRoad website: Step One: Navigate to Training Platforms from the Profile navigation menu on the TrainerRoad website here: Account > Connections > Training Platforms  Step Two: Select Connect under ROUVY Step Three: Read and Agree to the connection terms Step Four: If you’re already logged in to ROUVY, this will bring you to the ROUVY authorization page. Click “Authorize” to confirm the connection. (If you’re not already logged into ROUVY, you’ll be prompted to do so first). After clicking “Authorize” you’ll be brought back to the Training Platforms section in the TrainerRoad settings menu. You have now successfully synced ROUVY and TrainerRoad! To confirm that the connection has been made successfully, a green border and an option to disconnect will now appear in the ROUVY option on the page. Check out this article for instructions on completing your TrainerRoad workouts within ROUVY. What Syncs Between the Two Platforms?  Upcoming TrainerRoad Workouts: Today's planned TrainerRoad cycling workout will be pushed to ROUVY.  Note: Ramp Tests and FTP tests will not sync to ROUVY! All other indoor workouts scheduled today will be sent over to ROUVY on the day that they are scheduled. Completed ROUVY Activities: Workouts completed in ROUVY will be pulled back into TrainerRoad.  When are Workouts Synced Between Platforms?  TrainerRoad Workouts: TrainerRoad Workouts scheduled for today will be pulled into ROUVY almost as soon as they are scheduled. Once a workout has been synced to ROUVY, you’ll notice the ROUVY icon appear in its footer on your TrainerRoad calendar.  Workouts sent to ROUVY will appear prominently on the day they are scheduled on the ROUVY home screen.   They’ll also appear as the first item in the ROUVY “Workouts” tab: Completed ROUVY Activities: Workouts completed in ROUVY after establishing a connection between ROUVY and TrainerRoad will be synced to TrainerRoad shortly after ending the workout. This sync may take a few minutes. Historical training data in ROUVY won't be pulled into TrainerRoad.  How to Disconnect ROUVY and TrainerRoad Step One: Navigate to Training Platforms from the Profile navigation menu on the TrainerRoad website here: Account > Connections > Training Platforms Step Two: Select Disconnect below ROUVY and then Disconnect to confirm the change. You have successfully disconnected ROUVY and TrainerRoad! You can re-enable the connection at any time by following the steps above.  Frequently Asked Questions For more information and answers to Frequently Asked Questions about ROUVY and TrainerRoad check out our FAQ article here: Training in ROUVY with TrainerRoad: FAQs.
General Usage • Last updated on Sep 28, 2026
Workout Availability and Access What workouts will appear in ROUVY? If you are following a plan, your indoor TrainerRoad workouts scheduled for today will automatically appear in ROUVY. Workouts will not be sent to ROUVY on your plan’s scheduled rest days. If you aren't following a plan, a recommended workout of the day will automatically appear in ROUVY when you open up the app. Where do I find my workouts in ROUVY? Today’s workout appears near the top of the ROUVY app “Home” screen, as well as prominently near the top of the “Workouts” page.  What if my workout doesn't appear in ROUVY? First, check that it is scheduled for today, as workouts scheduled on future days aren’t synced until the day they are scheduled. Any changes in TrainerRoad may take a few minutes to appear in ROUVY. What happens to removed calendar workouts? Workouts removed from your TrainerRoad calendar will also disappear from ROUVY. This might not always happen immediately. Will planned runs sync over to ROUVY?  No, only planned indoor cycling workouts will sync to ROUVY.  FTP and Power Settings Will my TrainerRoad FTP sync to ROUVY? No. While workout targets are based on your TrainerRoad FTP, you'll need to manually update your FTP in ROUVY to match. This only affects the color-coding of workout blocks in ROUVY, not their actual power targets. Will my ROUVY ride count for AI FTP Detection? Yes, TrainerRoad workouts completed in ROUVY count toward AI FTP Detection. Does the sync affect my Progression Levels? Yes, workouts completed in ROUVY will update your TrainerRoad Progression Levels just like regular TrainerRoad workouts. Training in ROUVY Can I still do ERG mode workouts in ROUVY? Yes, though ERG behavior may feel slightly different than in TrainerRoad. Does drafting affect ERG mode workouts? Drafting other riders in ROUVY should have no impact on your ERG workouts. Can I use ERG mode with route resistance? No, ROUVY’s structured workout mode disables terrain resistance. Toggling ERG off in ROUVY during a workout switches to a steady resistance mode that is not impacted by terrain. Can I extend workout segments in ROUVY? No. You can’t extend your warmup and cool down in ROUVY like you do in TrainerRoad. When your structured workout ends, your workout does, too. If you’d like to ride more we recommend starting a new ROUVY activity immediately after your workout. Can I adjust the warmup/cooldown intensity? Yes! ROUVY limits intensity adjustments to 150% of the original target power, though. For higher intensities, you can exit ERG mode and shift into harder gears. What if I want to continue riding after my workout? You can’t keep riding in the same ROUVY activity after completing the structured portion. If you’d like to ride more we recommend starting a new ROUVY activity immediately after your workout. What if I complete my chosen route in ROUVY before finishing my TrainerRoad workout? If you ride to the finish of your selected route before your workout is complete, you'll automatically restart the route. Your workout will not be cut short. Post-Workout and Syncing When will my ROUVY ride appear in TrainerRoad? Rides typically sync within a few minutes. You may need to refresh the TrainerRoad app to see the completed workout. How do surveys work with ROUVY? You'll receive a survey prompt in ROUVY right after completing your workout. You can also complete the survey through the TrainerRoad app. What if I toggle RPE surveys off in ROUVY? If you click "Don't show this again" on the ROUVY postworkout RPE survey screen, you'll no longer receive the survey after your workout in ROUVY. We don't recommend doing this, because your RPE response is very important for TrainerRoad AI to optimize your training. If you do toggle them off, they can be reenabled later from the "General" section of the ROUVY app settings menu. You can also always update your survey response later by clicking the completed workout within TrainerRoad. What appears in Strava after a ROUVY workout? The activity will appear as "ROUVY - [TR Workout title]". You can edit this title in Strava without affecting the TrainerRoad sync. Will my workout visualization look different in TrainerRoad? Yes, completed ROUVY workouts show the map and elevation data rather than TrainerRoad's traditional workout profile. How do I see my workout details in TrainerRoad after completing it in ROUVY? From the calendar, click the workout name in the TrainerRoad Workout box to view the original workout description and details. What appears in my TrainerRoad calendar? Occasionally, for a few moments after completing your workout, you may see both the ROUVY activity and planned TrainerRoad workout. These will merge automatically. How do I know if a workout synced successfully? For planned workouts, the ROUVY icon will appear in the workout’s footer on your TrainerRoad calendar once it’s successfully been pushed on the day it is scheduled. The completed workout will appear in your TrainerRoad calendar with "ROUVY" noted as the source.  Additional Features Will workout instructions appear in ROUVY? Yes, for workouts that include instructions in TrainerRoad. You can check if a workout has instructions on its detail page or disable them entirely through TrainerRoad app settings. Do I need both apps open during workouts? No, you only need ROUVY running to complete your workout. TrainerRoad doesn't need to be open. Do I need to download TrainerRoad to complete workouts in ROUVY? Nope. You don’t need the TrainerRoad app to complete workouts in ROUVY. If you want to make adjustments to your TrainerRoad training plan, build a new plan, or adjust your TrainerRoad settings you can do all of these things from the website. Will outside workouts sync to ROUVY? No, only indoor versions of workouts will sync to ROUVY.  Will group rides and other calendar items sync to ROUVY? No, only structured TrainerRoad workouts will appear in ROUVY.
How to Complete TrainerRoad Workouts in ROUVY
You can complete TrainerRoad cycling workouts in ROUVY when you connect your ROUVY account to your TrainerRoad account. Here’s how to get set up and started. Getting Started To complete TR rides on ROUVY you will need the following: - An active TrainerRoad subscription - An active ROUVY subscription - The latest version of ROUVY on the device you train on. If you don’t have the ROUVY app you can download it for Mac, iOS, PC, and Android here: ROUVY Download Step One: Connect ROUVY and TrainerRoad You'll establish syncing between the two platforms through the TrainerRoad website: Step One: Navigate to Training Platforms from the Profile navigation menu on the TrainerRoad website here: Account > Connections > Training Platforms  Step Two: Select Connect under ROUVY Step Three: Read and Agree to the connection terms Step Four: If you’re already logged in to ROUVY, this will bring you to the ROUVY authorization page. Click Authorize to confirm the connection. (If you’re not already logged into ROUVY, you’ll be prompted to do so first). After clicking Authorize you’ll be brought back to the Training Platforms section in the TrainerRoad settings menu. You have now successfully synced ROUVY and TrainerRoad! To confirm that the connection has been made successfully, a green border and an option to disconnect will now appear in the ROUVY option on the page. Step Two: Choose How You Want to Ride What gets imported into ROUVY will change depending on whether you have scheduled workouts in your TrainerRoad calendar or not. Here are the two main options for completing TR rides in ROUVY. Follow a Plan If you are training for a race or an event we recommend following a training plan. When you are following a TrainerRoad plan workouts scheduled on your Calendar will automatically be pulled into ROUVY on the day that it is scheduled. If you haven’t added a plan to your calendar and would like to follow a custom training plan check out this article to get started: Plan Builder Overview Get a Recommended Workout Everyday No plan, no worries! TrainerRoad will automatically send a recommended workout of the day over to ROUVY when you aren't following a plan. When you want to do a ride just open up the ROUVY app and today's recommended workout will appear right at the top of the home screen, as well as at the top of the Workouts tab. The only time you won't get a recommended daily workout is when you have a recommended rest day. To learn more about recommended rest days check out: Fatigue Detection Step Three: Complete your TrainerRoad Workout in ROUVY! After you have established the connection between the two platforms and decided how you want to train you are ready to ride. Here is how to access and complete your TrainerRoad workout in ROUVY: Step One: Open the ROUVY app and log in to your ROUVY account. Step Two: Make sure your trainer/ power meter/ other devices are connected to ROUVY. If needed, click the devices bar at the top of the screen to connect your devices. Step Three: If you have a scheduled TrainerRoad workout today, it will appear right on the ROUVY home page.  It will also appear at the top of the Workouts tab. Step Four: Click on the workout. This brings you to a preview screen that shows more information about the workout and allows you to customize your workout route. Step Five: Select your preferred route and click Start Workout. Step Six: Start pedaling to begin your workout. The workout profile will appear at the bottom of the screen, while upcoming intervals are listed along the upper left of the screen. After the Ride Your ROUVY ride will end automatically when your TrainerRoad workout is complete. Post-Workout Surveys After you complete your ride you will be prompted to fill out a survey rating your effort. Rate the perceived effort of your ride with 1 being Easy and 10 being a maximum effort. Your RPE response is very important for TrainerRoad AI to optimize your training, so we don't recommend clicking "Don't show this again". If you do toggle them off, they can be reenabled later from the "General" section of the ROUVY app settings menu. You can also update your survey response directly in TrainerRoad at any time later on. For steps on how to do this check out: Post Workout Surveys  Your Next Workout If you aren't following a plan - no need to do anything else! You will automatically get a recommended workout of the day next time you open up the ROUVY app.  If you are following a training plan your next workout will appear on the ROUVY app Home screen, as well as in the “Workouts” tab, when you open the app on the day it is scheduled.  If you are on a Training Plan, you won’t see a TrainerRoad workout pushed to ROUVY on days when your plan has no workouts scheduled, since these are intended to be recovery/rest days. Ride Sync Your completed ride will automatically sync to TrainerRoad once you have ended the workout. If you'd like your completed workout to sync to any other platforms, such as Strava, you will need to enable third-party syncing through ROUVY. Frequently Asked Questions For more information and answers to Frequently Asked Questions about ROUVY and TrainerRoad check out our FAQ article here: Training in ROUVY with TrainerRoad: FAQs. - How to Complete TrainerRoad Workouts in ROUVY - Step One: Connect ROUVY and TrainerRoad - Step Two: Choose How You Want to Ride - Step Three: Complete your TrainerRoad Workout in ROUVY! - After the Ride
TrainerRoad Basics • Last updated on Sep 28, 2026
