Compatible Trainers
By Alex Kizis • Last updated on Aug 20, 2026
Smart Trainers
TrainerRoad is compatible with most smart trainers currently on the market. You can use our Equipment Checker, to see if your specific smart trainer is compatible!
If you don't see your smart trainer on this list don't worry. If your trainer has can connect via Bluetooth or ANT+ there is a good chance it is compatible with TrainerRoad.
Power Meters
You can use any trainer you'd like if you're pairing your power meter to TrainerRoad. The power meter will communicate directly with the TrainerRoad software, so there's no need to input the make and model of the trainer you're using.
VirtualPower
Plan on using our VirtualPower feature to work out? Check out VirtualPower. Use the Equipment Checker to confirm your trainer is supported.
I'm about to purchase a trainer. Any recommendations?
We highly recommend the Kurt Kinetic Rock-and-Roll, the Kurt Kinetic Road Machine, and the CycleOps Jet Fluid Pro.
I already have a trainer that isn't one of the models you recommend. What are the brands you support?
If your trainer isn't listed in the Equipment Checker, don't worry! You can most likely still use VirtualPower with a different trainer setting.
Take a look at the following article for recommended alternatives: My Non-Smart Trainer Is Not Listed — Can I Still Use TrainerRoad?
1 out of 2 found this helpful
