Skip to content
FTP Testing - The Cornerstone of Training
Few components of power-based training are as important as measuring and tracking FTP. In fact, it could be argued that nothing short of actual performance ranks as highly in terms of overall importance. With this in mind, we offer the following primer on what your FTP represents, what an FTP test is, how and why we assess FTP, and when we assess it.
What is FTP?
Functional Threshold Power (FTP) is — quite simply — a measure of fitness.
FTP represents the power (measured in watts) that you could theoretically maintain for about an hour, and it's the single metric we use to scale each of your workouts in our shared quest to keep your fitness growing.
With regards to what's taking place within your body and the muscles themselves, riding at your FTP pushes you right up to that limit where pushing any harder will drastically limit the duration of your ride.
But as long as you stay just below that acidic tipping point where your muscles light up and uncomfortably tolerable minutes become barely tolerable seconds, your muscles are in balance with the workload - for about an hour, anyway.
What is the FTP Assessment?
An FTP assessment is a snapshot of your fitness at any point in time. By measuring your fitness and assigning it a number, we can track changes in your fitness over weeks, months, and years. The assessment we use to measure this level of fitness is our Ramp Test.
How is FTP Calculated from the Ramp Test?
TrainerRoad will automatically calculate your FTP upon completion of your Ramp Test workout.
If ridden correctly, you can expect your FTP to be about 75% of your highest 1-minute power sustained during the test.
Note: More complicated calculations may be applied when determining FTP from a Ramp Test depending on how accurately a rider followed the format of the test. This means, 75% of a rider's 1-minute power may not translate to their actual FTP calculation.
How is Functional Threshold Power Assessed?
During a Ramp Test assessment, riders first follow a sufficient, stepwise warming period before progressing to their higher-intensity steps.
The power that you average over the last, highest minute of your test allows us to mathematically estimate your current FTP. The goal here is to obtain a reasonably close estimate of one's sustainable power, or in power-based training nomenclature, your Functional Threshold Power/FTP.
Why Do We Assess FTP?
By assessing FTP, not only can we track changes in fitness, but we can also establish training zones, i.e. power levels. And as your fitness changes, we can update these power levels accordingly.
Each type of interval, e.g. Tempo, Sweet Spot, VO2max, etc. represents a percentage of your FTP. For example, Tempo intervals fall in the 76-90% FTP range while VO2max intervals fall in the 106-120% FTP range.
Different types of intervals target different energy systems and consequently different training adaptations, so it's important to have a personal measure of your fitness that will allow us to tailor your workouts to your specific needs and capabilities.
When Should I Assess My FTP?
It's a good idea to assess your FTP prior to beginning each training season unless you already have a good sense of your current fitness and your sustainable power. But even if you think you have a good grasp on your current fitness, it's still a good idea to back up your perception with actual performance.
It's also recommended that you assess or reassess FTP before embarking on a new training plan.
Finally, you should reassess your FTP about every 4-6 weeks in order to account for changes in your fitness and to keep your power levels in line with your performance potential.
What if I'm Feeling Stronger Before My Scheduled FTP Test?
Of course, testing roughly every 4-6 weeks is just a general guideline. Your FTP very well may have increased prior to 4-6 weeks after your last test.
If you find yourself breathing easily through workouts with high-Intensity Factors (IFs)® or that you're often manually increasing the workout intensity before it's time for your next test, don't hesitate to manually edit your FTP. No need to wait for an FTP test if you know you're stronger. :)
25 out of 27 found this helpful
