Skip to content
Choosing the Right Discipline For Your Events
TrainerRoad builds your plan around your A event's selected discipline or type.
This guide is here to help you understand what each discipline trains and how to choose a match for your event.
Why Event Type Matters
Your event type influences:
  • Which training phases you get (for example, a plan that emphasizes sustained power vs short, punchy power)
  • Which training zones and workout profiles are emphasized
  • What fitness you are most prepared to express on event day
No discipline is “better” than any others. Each discipline simply trains your body in a different way to prepare for different event demands.
The Simple Way to Choose
In many cases, the event’s advertised label is enough:
  • Criterium → Criterium
  • Time Trial → Time Trial
  • Cyclocross → Cyclocross
  • XCO, XCM, Short Track → the matching MTB discipline
  • Triathlon Event → the matching triathlon discipline
It gets trickier when the event label is broad, like Road Race, Gravel, or Gran Fondo. When that happens, use these four factors to identify the dominant effort type your event will demand:
  1. Advertised discipline
  2. How long you will ride (duration)
  3. Climbing profile (how many climbs, how long, how steep)
  4. Your goal (race for results vs ride for a steady finish or target time)
A helpful reminder: distance alone is not a reliable guide. The same distance can mean very different effort types depending on terrain, surface, and speed. Duration tells you much more about pacing demands.
A quick Decision Guide For More Ambiguous Road & Gravel Events
Road races: Rolling Road Race vs Climbing Road Race
Start here if your event is a mass start road race and you are unsure which road discipline fits.
  • Rolling Road Race is usually best when the decisive moments are repeated surges, attacks, and short climbs. Think punchy efforts and frequent changes in pace.
  • Climbing Road Race is usually best when long, sustained climbs are the defining feature. Think sustained climbing power and longer efforts.
Helpful shortcut:
  • If the key climbs are short and punchy, lean Rolling.
  • If the key climbs are long and sustained, lean Climbing.
If you are not sure, pick the discipline that best matches where you expect the hardest efforts to happen. On some courses, long climbs early do not decide the race, and the event can still be ridden like a Rolling Road Race.
Long Road Events: Gran Fondo
Gran Fondo is the best fit for events where the dominant demand is steady pacing and endurance.
  • Typical match: long road events where your goal is to finish strong, ride a steady pace, or hit a target time.
  • Terrain can be flat or mountainous. For most riders, the pacing challenge is still the main limiter once the duration is long enough.
Gravel Events
Gravel events can be very different, so the best match depends on duration and how the event is raced.
  • If your event is primarily a long, steady endurance day where pacing is the priority, Gravel is usually the best fit.
  • If your event is shorter and raced aggressively with frequent surges, you may also consider Rolling Road Race, Climbing Road Race, or Cross Country Marathon, depending on terrain and surface.
Helpful shortcut:
  • Over about 4 hours: Gravel is usually the best starting point because pacing and endurance are critical for most athletes.
  • Under about 4 hours: Gravel still works well, but a more race-focused discipline(Rolling/Climbing Road Race) can be a good option if the event is punchy and you are racing for position.
Time Trials
Time Trial discipline is built around steady, controlled efforts against the clock.
  • Best fit: most TTs, especially flatter courses or those where pacing is steady and continuous
  • If your TT is unusually punchy or very climb-heavy, Climbing Road Race can be a reasonable alternative, depending on how the effort actually feels on the day.
Hill Climbs
There is no dedicated hill climb discipline, so match based on climb duration:
  • Over about 20 to 30 minutes: Time Trial
  • About 2 to 30 minutes: Climbing Road Race
  • Under about 2 minutes: Rolling Road Race or Climbing Road Race (choose based on whether the effort is more punchy or more sustained)
If you are doing a season of mixed hill climbs, Climbing Road Race is usually the most well-rounded option.
Stage Races
Stage races are their own category because day-to-day recovery becomes part of the performance demand.
Choose the discipline that matches the stage race type you are doing. If your stage race includes mixed stages, pick the discipline that best represents the dominant demands across the event.
Off-Road Event Types in TrainerRoad
Off-road events vary significantly. The easiest way to pick the right TrainerRoad event type is to match the discipline to the effort you will repeat most often: short surges, sustained hard laps, or long pacing with hard climbs late.
Short Track Cross Country (STXC)
Pick STXC if your event is:
  • About 20 to 30 minutes
  • Very fast and intense with constant accelerations
    This plan builds repeatable high-intensity efforts and quick recovery between surges.
Cross Country Olympic (XCO)
Pick XCO if your event is:
  • About 60 to 100 minutes
  • Lap-based with repeated climbs and technical features
    This plan builds the ability to repeat hard efforts near and above threshold across a full race-length effort.
Cross Country Marathon (XCM)
Pick XCM if your event is:
  • About 3 to 8 hours
  • Off-road with meaningful climbing and repeated hard sections
    This plan builds long endurance and fatigue resistance, while still preparing you for surges and hard climbs late in the race.
Cyclocross (CX)
Pick Cyclocross if your event is:
  • About 45 to 70 minutes
  • Constantly changing pace with repeated bursts, corners, and short run-ups
    This plan builds repeatable high-intensity efforts and recovery for one-hour racing.
Off-Road Triathlon
Many off-road tri formats align closely with Olympic distance demands on the bike, even if the bike leg is shorter, because the terrain is more demanding.
  • Best starting point: Off-Road Triathlon
  • Only choose Sprint, Half, or Full if the event distances truly match those formats
Quick Tie-Breakers
  • XCO vs XCM: around an hour and very intense, choose XCO. Multi-hour pacing with hard climbs late, choose XCM.
  • XCM vs Gravel: if it feels like an off-road race with frequent punchy efforts, choose XCM. If it is more about steady pacing for a long day on mixed surface, choose Gravel.
Common Exceptions: When A Different Event Might Help You
If there is more than one good option, that is normal. Look at your event’s advertised type, expected finish time, and whether you are racing for results or pacing for a finish or target time.
Long events where you are racing for results
If the event is long but your goal is explicitly competitive and the race is likely to be decided by surges, attacks, and climbs, you may choose a discipline that places more emphasis on variability and intensity.
That can be a good choice, but there is a trade-off:
  • More emphasis on punchy and race-like fitness
  • Less emphasis on the deepest steady endurance compared to Gran Fondo or Gravel
If your main goal is to pace steadily and finish strong, Gran Fondo or Gravel is still usually the best match.
longer climbing events or stage races where you will ride a steady pace
In these cases It can be smart to pick a Gran Fondo or Gravel plan, to train for smooth steady efforts instead of training to chase and make breaks up a climb.
Mixed terrain/discipline race like a stage race or mixed surface event
In those cases, pick the discipline that best matches:
  • The effort type you will spend the most time doing
  • Will you be holding a steady pace, or chasing and making breaks?
  • The effort type you most want to improve for your goal
An example could be a longer event where you ride Road, Gravel, & Single Track with plenty of elevation gain:
  • If you intend to hold a steady pace, Gravel would be a good choice.
  • If you are going to race it, Climbing Road Race or Cross Country Marathon would better fit that intent for most athletes. Between those you would want to pick what you want to improve.
Have More Than One A event?
A events should be planned at least 8 weeks apart. TrainerRoad will focus the plan around your A events, in order. After each A event, the plan can shift focus toward the next A event. After the final A event, the plan uses your last B event discipline, or your last C event discipline if there is no B event. A events are the strongest drivers of plan focus.
Changing Your Event Type
In many cases, you can change an event’s discipline. When you do, TrainerRoad may prompt you to update your plan so training matches the new discipline.
There are a few situations where changing discipline requires deleting and recreating the event instead, such as switching between cycling and triathlon categories, or switching between stage race and single-day event categories.
FAQs
How do I Build a Custom Training Plan?
You can use the resources below to learn how to build a custom plan and to dig deeper into their structure:
How to Choose Which Event to Make My A Event?
In most cases, you want your A event to be your primary event for the season. You can learn more here:
I'm not Training For an Event, What can I do?
TrainerRoad has many goal-based plan options as well. You can learn about them here.
How Should I Choose the Event Intensity?
It's helpful to think of the intensity rating of the event as the aspirational pace you want to ride it. Every athlete is different but here is a bit of general guidance:
  • Recovery - Tempo could be an all-day or repeated-day effort(rest day or easy day during a stage race).
  • Tempo - Hard could be a race level effort for 3-8 hours.
  • Hard - All out efforts would be a max level effort for shorter events(1-3 hours)
1 out of 1 found this helpful
