Skip to content
Syncing TrainerRoad workouts with your Garmin Connect account is easy! Our Activity Sync feature allows you to automatically upload all completed TR workouts to your Garmin Connect account, and automatically adds all completed Garmin Connect cycling workouts to TrainerRoad. Read on to find out how!
Important to Know Before Syncing
  • TrainerRoad can only access your previous 5 years of workout activity from Garmin Connect.
    • You must upload a new workout activity to Garmin Connect in order for your previous 5 years of workout activity from Garmin Connect to sync to TrainerRoad.
    • TrainerRoad will only sync your previous 5 years of workout activity from Garmin Connect once during the first connection. If you disconnect and delete your Garmin Connect workouts from TrainerRoad, they will not sync again upon reconnection.
  • Your past TrainerRoad rides (those done before connecting) will not be synced to Garmin Connect. Once Garmin Connect is connected to your TrainerRoad account, all your future completed rides will automatically sync to both accounts.
  • If you have not set your timezone in Garmin Connect, your ride will show up under the default UTC date/time. You can manually edit the date/time in Garmin Connect by selecting Account Settings >Display Preferences >Upload Time Zone Setting.
  • If you’ve been offline for a week or more and you have a bunch of completed rides queued up, there’s a chance some rides may not sync over to Garmin. This is because we’re limited to sending 10 workouts/day per user.
  • TrainerRoad rides that are under 10 minutes will not sync over to Garmin Connect.
  • If you want to complete TrainerRoad workouts outside on your Garmin device you can follow these steps: Pushing an Outside workout to Garmin[click]. Outside workouts can be pushed to Garmin up to two days in advance.
How to Automatically Sync All of your TrainerRoad and Garmin Connect Rides
1. Log into TrainerRoad to access your Account Profile.
2. Select “Account” and "Connections" from the menu on the left-hand side of the screen.
3. Click the option to “Connect with Garmin.”
4. Authorize TrainerRoad to access your Garmin Connect account by selecting “Agree & Connect.”
  • This will open a new window prompting you to log into Garmin Connect
5. Log in to Garmin Connect
6. Next you'll be prompted to control what information you share. Enable all the toggles.
  • The "Historical Data" toggle is disabled by default. Manually enable it for your training history to sync to TrainerRoad.
7. Select "Save" and TrainerRoad will sync to your Garmin Connect account and data.
How to Manually Sync Individual Workouts to Garmin Connect
  1. Navigate to your Career page on the web and click on the workout you'd like to push from the Current Week section
  2. Select "Push to Garmin" as shown below:
How to Manually Upload Individual Workouts to Garmin Connect
You can also manually add completed TrainerRoad rides to Garmin Connect. All you need to do is download your workout in a .fit file — the file type required to upload rides to Garmin Connect.
Here's how you do it.
Obtaining the .fit Workout File
There are two ways to download your TrainerRoad workout to upload to Garmin Connect:
1a. Online
First, log into trainerroad.com. Once logged in, select "Past Rides" just under the "Career" option in the top-left corner.
Navigate to the rides page of your career. On the online Ride page, click the Download arrow below the workout profile in the upper right-hand corner. This will Download your Ride file.
  • Note: rides that have just been completed may need a few minutes for processing before the download is ready.
1b. TrainerRoad Application
Once logged into the app, click on the Calendar tab and scroll up until you've found the date of your workout. Click on your workout, and the workout summary will appear on the right. Click on the ellipses menu on the bottom part of the summary, then click "Download".
Upload to Garmin Connect
2. Next, log into Garmin Connect and select the "+" symbol.
3. From here, select "Browse" to search for your .fit file.
4. After you upload the file you'll be able to view the ride in Garmin Connect.
Troubleshooting
If you're having trouble syncing rides to or from Garmin Connect, follow the steps below.
  1. Navigate to the Activity Sync page.
  2. Select the Refresh Button for Garmin. Keep in mind it may take a few minutes for rides to sync over after re-authorizing.
If you're still running into trouble, reach out to our support team here and we're more than happy to help!
If you want to learn how to run TrainerRoad workouts on your Garmin Edge, you can check out this article.
4 out of 8 found this helpful
