How to Analyze Power Records
By Corey C. • Last updated on Aug 17, 2026
Power Records chart on TrainerRoad shows your best power for every duration and lets you compare any time periods side by side to see exactly how your fitness is changing.
Note: The Power Records chart is available on the TrainerRoad website, not in the mobile app.
What is a Power Record?
A Power Record is your highest power output for a specific length of time. From your best one second power to your best two hour power, your bests are tracked for you no matter what sort of event you are training for. Power Records are earned from both indoor and outside rides.
A Power Record is shown by a small trophy icon on any completed ride in your account.
This completed ride has earned Power Records, shown by the small trophy icon.
When you open the details of a ride, you will also see how many season specific and all time Power Records you earned in that ride.
Total Power Record count is shown next to the season, or all time, name.
Why do I have so many Power Records?
Power Records are different for every athlete and rider type. The number next to the trophy icon is how many you earned during that ride.
TrainerRoad calculates Power Records at intervals across your whole ride, so a single ride can set a lot of them. Each rider type cares about different durations. A sprinter watches 30 seconds and under, while an endurance rider wants to see much longer efforts.
How often records are awarded depends on ride length:
  • 0 to 5 minutes: awarded every second
  • 5 to 30 minutes: awarded every 5 seconds
  • 30 minutes to 2 hours: awarded every 30 seconds
  • 2 hours and longer: awarded every 5 minutes
Getting Power Records across the whole ride lets you focus on the durations that matter most to your riding. Do not be surprised by a ride with a large number of them. That is a good thing.
Import your outdoor rides into TrainerRoad
Sync your TrainerRoad account with Garmin Connect and/or Strava to bring in your outdoor ride history and all future outdoor rides. Outdoor power counts toward your Power Records right alongside your indoor workouts.
What is the Power Records chart?
The Power Records chart plots your best power for every duration as a single curve, so you can see your whole power profile at a glance and track how it changes over time. With it you can:
  • See your best power for any duration, from 1 second to several hours
  • Create custom Seasons (your own training and racing periods) to analyze
  • Compare up to three time periods at once: Seasons, quick ranges, or custom date ranges
  • Switch between average Power and Normalized Power (NP)
  • Focus on a duration range: Total (all durations), Sprint (1–30 sec), or Endurance (30 sec +)
  • Click any point to see the exact ride(s) where you set that record
  • Open a ride's full Ride Analysis page to dig deeper
  • Use SeasonMatch to compare the same weeks of two different Seasons
Finding your Power Records
Step One: Login to your account on the TrainerRoad website.
Step Two: In the left sidebar, select Career and click Power Records.
Reading the chart
Each line on the chart is one time period you've selected. The horizontal axis is duration (how long you held the power); the vertical axis is power in watts. A higher line means more power for that duration. Hover or click any point to see the watts and the ride behind it.
Power vs. Normalized Power
Use the Power / NP toggle above the chart to switch what the curve shows:
Power: your best average power for each duration.
NP: your best Normalized Power, which accounts for the surges in a ride.
To the far right of the power filter you can also filter for duration. Total includes all power durations while sprint captures power outputs between one and thirty seconds and endurance captures anything longer than that.
Create and Manage Seasons
A Season is a custom period of training and racing that you want to analyze. A month, a training block, or a race build are all custom seasons you might create.
To create one, open any of the range selectors above the chart and click Seasons, and then select Manage Seasons. In the Manage Seasons panel, click + Add New Season.
From there you can give it a Season Name, set the start and end dates of the season and hit save. Seasons can cover any past, present, or future period. You can create several so you can compare your power at different points in your training.
Above the chart are three range selectors. Each one can hold:
  • A Season you created
  • A Quick Range: All Time, Year to date, Last 6 weeks, Last 90 days, or Last year
  • A Custom Range: any start and end date you choose
    (You can also limit a range to Indoor workouts only.)
Select two or three ranges to overlay them and instantly see how your power compares.
See the rides behind a record
Click any point on the chart to pin a tooltip for that duration, then click View Details. The View Power Records Details window opens with three tabs:
Drill Into Individual Rides
From the details window, click a ride to open its full Ride Analysis page, where you can study the effort that set the record.
Power Profile
Below your Records you will find your power profile with a quick view of your all time power records, power records from last year and power records from this year so far. You can hover over individual records for links to the rides with those records.
3 out of 4 found this helpful
