Skip to content
Home Search Results
21 results for “Too Much Time”
Found 21 results
How to Add A, B, and C Events to Your Calendar
A key component of any training plan is knowing when your events are going to take place and how you are going to prioritize them. With Calendar, you can add events at any time and TrainerRoad will adapt your plan accordingly. What Types of Events Are There? Before adding any events to your Calendar it’s first important to know the different classifications of events. As athletes, races are often very important to us. For many, it's the whole reason we train, and in an ideal world, we would roll up to each race with the ability to perform at our maximum physical potential. However, the reality is that the human body cannot maintain the optimal conditions required to perform at its absolute peak for very long. "Peaking", as we call it, requires an optimal balance of fitness and freshness, and these "stars align" for only a brief window. Through the use of our Training Plans, you'll be able to plan your season so that the "stars align" on the day that your performance is most important to you. The first step of Building your season is Event & Race Prioritization. The terminology we use for this is A, B, and C races. Below, we’ll explain how each of these types of races will fit into your season. A Race - These will be races that you will perform at your absolute peak fitness and should be events that are the most important to you. It is best to have around one or two "A" races per year. - If you have multiple A races, they should be at least 12 weeks apart in order to be in peak form for both. If you have two A races within 12 weeks of each other, we recommend prioritizing one as an A race and the other as a B race. - "A" races often have two-week tapers leading up to them, which call for a reduction in overall Training Stress resulting in an increase in freshness, all while maintaining fitness to create this elusive "Peak.” B Races - While you won’t be fully peaked for these, B races will be excellent trials of your fitness, and you can still be very competitive in them. Keep in mind that your competitors are restricted by the same human limitations as you are, so while you can’t always be in your absolute peak form, they can’t either. - While these races can be season objectives in their own right, they mostly allow you extra opportunities to try different race/nutrition strategies to see what works for you and your body. - These races can be particularly important because they build mental racing experience and confidence that you can carry into your higher-priority "A" events. - You will be given the option to add opener workouts in the days leading up to their B race when adding events using Plan Builder. C Races - These races are strictly for practice, experience, and fun. The outcomes should carry much less emotional value, and as such, you will simply "train through" them. They should hold a similar value as a key hard workout. - Keep in mind that structured work is what makes you faster, not simply riding hard all the time, and recovery is just as important. - Since these are essentially viewed as a form of training, no taper is required, and if possible, you should schedule them in the same manner as which you’d find a really tough workout, i.e., following an easy or off day. Takeaway: You can't perform at your peak physical fitness forever, so it is important to decide when you want to be your fastest and plan accordingly. How Event Priority Affects Adaptations - A Events - TrainerRoad will add a taper for the event and an opener workout the day before the event (if you've enabled this option in the Plan Builder flow). - B Events - TrainerRoad will add an opener workout the day before the event (if you've enabled this option in the Plan Builder flow). - C Events - These events are essentially training/workouts, no taper is involved so TrainerRoad will remove any scheduled workouts on this day. For more on how to prioritize your events to build a training plan, check out this Article: - How to Prioritize Your Races and Build a Seasonal Race Plan Adding an Event to the Calendar 1. To add a Race/Event to your calendar, either click on the specific day that your event will take place, or the "+ Add" button on the top right part of your screen. 2. Select "Event" from the drawer on the right of the screen. 3. Enter the pertinent information regarding the event, such as whether it's an A, B, or C event, its duration, and intensity, etc. 4. Once the event is added, you'll be prompted to adapt your plan to include the event. Select "Adapt". Editing an Existing Event in the Calendar To edit an Event, simply select it from the Calendar to open the dialogue box then click the Edit/Pencil icon. To simply move the event, you can also drag and drop the event from one day to another if, for example, it was rescheduled. After editing your Event adaptations will be prompted based on A, B & C Events prioritization. Marking an Event Complete If you import an outside ride file on the day of your event, it will automatically match that activity to the event and mark it as complete. In case that doesn't happen automatically you can also associate your event's ride file manually (see Match a Planned Workout with a Completed Workout/Ride). If you don't have a ride file for your event, you can also manually mark the event as complete by clicking on the event from the Calendar and selecting Mark as Complete. Add an Event in Plan Builder You can use Plan Builder if you'd like to build a training plan leading up to a specific event as well as add multiple events during the Plan Builder flow. To learn more about how to use Plan Builder check out this article: - Plan Builder Overview For more information on A, B, and C, races and how to prioritize them, check out the resources below! Podcast Discussion: [13:20] Podcast 134: How to Prioritize your races [31:30] Podcast 134: A, B, and C Race Definitions Further education: Peaking for Multiple "A" Races Not Enough Time Too Much Time! Related Training Articles: Peak on Race Day: 5 Questions to Plan Your Perfect Season
Your Plan & Calendar
Integrating Strength Training
As athletes, we all know that there is more to your performance than simply the muscles needed to push the pedals. Core strength is of course extremely important in cycling, as are the supporting muscles in your legs that help prevent injury. Time in the gym can certainly make you a healthier and more complete athlete, however, it also has the opportunity to derail your training to a certain degree. In order to maximize both your strength and cycling training, try to abide by these guidelines: - Try to pair your weight training within 12 hours of your intervals & preceding a rest/easy day. Ideally, you'll do your cycling first, but if you can't, just know that your riding will suffer since you're training on pre-exhausted legs. - Try to adhere to an on/off schedule by following hard days with easy ones. - Try not to block your training. It's typically far better to train then recover, train then recover, than to train & train then recover. Blocks can be productive, but they're risky and best left for particular times of the year, and often enough, more advanced riders. If you are not quite sure what workouts you should be doing to best improve your cycling, read on to learn about Chad's Top 5 workouts and how to work them into your training. Specifics and Progressions https://www.youtube.com/watch?v=HqmwjwTcOY8 Pistol Squats: Starting out: You want to begin at a squat depth where you can complete somewhere between 10-20 reps, alternating legs after each individual rep. When you can do 20 alternating reps properly, increase the squat depth and go back to shooting for 10 alternating reps; Progressions: You have a few options once you are able to complete 20 full-depth alternating repetitions. A few options are: - Grow to 30 alternating reps - Add weight and continue alternating legs with each rep - Stop alternating legs and do 10-15 reps straight on each leg before switching Side Planks: Starting out: Work up to holding a side plank for 90 seconds per side (do another exercise between sides rather than doing them back-to-back). Progressions: Once you can successfully hold a plank in proper form for 90 seconds, try these progressions: 1. Add movements such as leg abductions/raises, leg circles, etc. until you can hold a plank with motion for 90 seconds 2. Once you can do that, progress to hand-planks rather than elbow-planks Pushups: Starting out: Start with 2-3 sets of max # of PROPER pushups. Your goal is to work up to three sets of 20 pushups. Progressions: Once you can successfully complete three sets of 20 pushups, try these progressions: - Add alternating hip/knee flexion (spidermans/rock-climbers) until you can perform 3-5 sets of 20 pushups consecutively. - Another option is to add a weight plate to your back. Once you can do sets of 20 with the added weight, either increase the weight or add the spidermans/ rock-climbers mentioned above, but with weight as well. Deadlifts: Starting out: Find a weight you can properly lift for 15-20 reps. Be sure to nail your form EVERY rep, keeping in mind that without proper form you are at risk of injury and will not be working the intended muscles. Progression: Follow the below plan to advance your deadlifting capabilities: - Begin the first 4 weeks with 1-2 sets per workout, recover for 2-3 minutes when you work up to multiple sets. Focus on your form and make sure that you are doing them perfectly before piling on too much weight. - For the next four weeks, shrink the reps and grow the weight: rep range shrinks to 10-12 per set, weight increases such that 10-12 are difficult but doable, recover for 2-3 minutes between sets, and increase the sets to 3-5 per workout - For the next four weeks, move onto heavy lifts in the 3-5 rep range, 2-3 sets per workout, 5 minutes of recovery between sets. - Then move into maintenance with just 1 set, 3-5 heavy reps per workout, 1-2x/week, for the remainder of season. Renegade Rows: Starting out: Alternate moderate-tempo pulls for 20-24 reps (10-12/arm) with whatever weight you can move continuously. Progression: Once you can continuously complete 20-24 reps, try these progressions: - One option is to continue adding weight - Another option is to add a pushup between each repetition - The most advanced option is to complete a "man-maker" - This consists of: left row, pushup, right row, pushup, hop legs forward under your body, stand and shoulder dumbells, press both dumbbells overhead, return dumbbells to shoulders, return them to floor, kick feet back into pushup position, repeat for up to 20 total - If this ever becomes too easy for you, use more weight or add a speed element to progress even further
Making Your Plan Work
How to Test with the 20-Minute & 8-Minute FTP Tests
With the Ramp Test as our recommended assessment, we still offer two alternative options to test FTP: The 20-Minute and 8-Minute FTP Tests. How to Test During the test intervals, totally ignore the graph's recommendations. Whether you're above, below, or exactly in line with the graph makes no difference. It's important that these assessment efforts are not restricted or guided in any way. We're simply trying to get a reasonably close estimate of your Functional Threshold Power, something we can't do if your smart trainer is limiting your power. FTP (Functional Threshold Power) is automatically calculated upon completion of any of our test workouts. 20-Min VS. 8-Min Test If you do decide to use one of these alternative tests, whether you use our 20-minute Maximal Lactate Steady State (MLSS) interval or a set of 8-minute Power at VO2max (pVO2max) efforts, it's best to choose a format that you will stick with and one that fairly represents your fitness at the time. Each test has its own pros & cons. We'll elaborate on each of them briefly below in order to help you choose a format that best suits you, both in terms of your current capabilities & capacity for suffering. 20-Minute Test https://www.youtube.com/watch?v=nfdNQMik6Mk The 20-Minute Test is an ideal format to break into shorter, more manageable segments. By breaking the 20-minute effort into four 5-minute segments, riders can subtly tweak their effort every so often based on longer periods of muscular feedback, i.e. a rider can slightly reduce their pace every 5 minutes based on perceived exertion or how their body feels. The 20-minute test is a relatively long testing effort and pacing can sometimes be an issue for less experienced riders. Because of this, the 20-Minute Test is usually more ideal for seasoned riders who have a good sense of how to pace well. Additionally, many riders play it safe during the longer formats and end up finishing with too much gas left in the tank. Evidence of this is illustrated via a 2 or 3-minute surge in power at the end of an effort that would ideally be evenly-paced over the entire 20 minutes. As a result, their FTP and relative power levels are likely to be underestimated a bit (or a lot) rendering all subsequent FTP-based workouts less productive than they would be otherwise. TrainerRoad calculates your FTP from the 20-Minute Test by multiplying your average power for the test interval by .95. In other words, your FTP is 5% less than your average power of the test interval. 8-Minute Test https://www.youtube.com/watch?v=XmJr4r1pWYM Our preferred format for less experienced riders is the 8-minute protocol comprised of two 8-minute efforts. The 8-Minute Test yields a greater amount of information by demonstrating power at VO2max via each 8-minute interval, sustainable power/FTP once the average power of the two 8-minute intervals is reduced by 10%, and you can even track improvements in your aerobic fitness when comparing the 2 efforts afterward, i.e. a substantial difference could indicate a limited ability to recover & insufficient aerobic capabilities. TrainerRoad calculates your FTP from the 8-Minute Test by multiplying your average power of the two test intervals by .9. In other words, your FTP is 10% less than your average power of the two test intervals. Erg Mode vs Slope/Resistance Mode Building on the information found in our Erg Mode Explained article, these FTP test alternatives, when completed on a smart trainer, have to be done in the appropriate mode: Slope or Resistance mode (depending on your particular trainer). Fortunately, TrainerRoad switches modes for you when you assess your FTP via our 20-Minute Test or our 8-Minute Test. Why Erg Mode is Bad for the 8- and 20-Minute FTP Tests If a smart trainer is left in Erg mode during the testing portion(s) of a 20- and 8-Minute test, the workout will lock you in at your current fitness level instead of allowing you to pace the duration of the test interval at your own power target. To avoid this, the assessment needs to take place in Slope/Resistance mode in order to allow a rider to work at his/her own pace rather than having the trainer determine a pace based on the input FTP. TrainerRoad automatically switches you to Slope/Resistance mode during your test interval(s). If you wish to use a higher or lower Slope/Resistance setting, you're free to adjust it yourself and it makes no difference if you use different Slope/Resistance settings from interval to interval or test to test. The last setting you used will be applied the next time you enter Slope/Resistance mode. By switching to Slope/Resistance mode, you're allowed to go hard without being forced to maintain the calculated Target Power that would be forced on your legs in Erg mode. You can pace according to your current capabilities such that you ride as strongly as possible for the assessment interval(s).
FTP & Fitness Testing
How to Analyze Ride Data
Dig into the details of your indoor ride, including power, heart rate, cadence, TSS, Intensity Factor, and more in the workouts ride analysis page. You will see a ride analysis page for both indoor and outdoor cycling workouts with full breakdown of the workout and the data from that workout. How to Find a Workouts Ride Analysis Page Step One: Log in to your account on the TrainerRoad website. Step Two: In the left sidebar, select Career and click Activity List. You can filter by activity type, filter by zone, or search for a ride by name. ride-analysis-01-activity-list.png Step Three: Click any ride from this list to open its Ride Analysis page. You can also open a completed ride directly from your Calendar by selecting the ride on the Calendar and then selecting View Details: ride-analysis-14-calendar-drawer.png Everything Included in the Workout Analysis Page The workout analysis page includes a few different sections. Here's what each section includes and how to drill into them: The Workout Graph The graph at the top of the page shows your ride from start to finish. Move your cursor along the graph to see target power, heart rate, and power for any moment in the ride. ride-analysis-03-graph-tooltip.png Within the workout graph you can click and drag across the graph to select a section of your ride. The metrics panel updates to show stats for just that selection, so you can check the numbers on a single climb, interval, or surge. ride-analysis-04-drag-selection.png With a section selected, you can also use the buttons above the graph to, zoom In to magnify the selected section, add Interval to save the selection as a custom interval and reset to clear the selection and return to the full ride view. From the workout graph at the top of the ride analysis page you can also find: 1. Legend toggles: Click the items in the legend above the graph to show or hide each data series, like heart rate or Normalized Power. 2. Key Metric Panel: The panel to the right of the graph summarizes the ride, including duration, average and max power, heart rate, TSS, Intensity Factor, and kJ. For TrainerRoad workouts, your numbers appear next to the workout's target numbers. 3. Workout FTP: The horizontal line labeled with your FTP shows how the ride's efforts compare to your threshold at the time of this workout. Intervals The Intervals tab below the graph lists every interval in the ride with its duration, Normalized Power, average power, heart rate, and cadence. TrainerRoad workouts list each interval by name. Outdoor rides list the laps recorded by your bike computer, plus any custom intervals you create. ride-analysis-06-intervals-tab.png Click any interval in the table to highlight that section of the ride on the graph. The metrics panel updates to show the stats for that interval. ride-analysis-07-interval-highlight.png How to Create Custom Intervals You can also create custom intervals for a workout using the workout graph at the top of the ride analysis page. Here is how you can create a custom interval: Step One: Click and drag across the graph to select the section you want to save. Step Two: Click Add Interval above the graph. Step Three: Give the interval a name, fine-tune the start and end times if needed, and click Save. Your custom interval now appears in the Intervals table alongside the rest of the ride's intervals. ride-analysis-05-add-interval.png Power Zones The Power Zones tab shows how much time you spent in each power zone during the ride. Click a zone in the table to highlight that power range on the graph. You can also click Add Zone to create a custom zone with your own power range, and the bottom of the table shows which power source recorded the ride. ride-analysis-08-power-zones.png Power Records The Power Records tab shows your best power for every duration within this ride, from short sprints to the full ride. For TrainerRoad workouts, the Prescribed line shows what the workout asked for, so you can see how your effort compared. Use the date range selectors to compare this ride against other time periods, and use the toggles above the chart to switch between Normalized Power, average power, and heart rate. To explore your all-time power records across every ride, see How to Analyze Power Records. Analyzing Your Outdoor Ride Data Outdoor rides have everything that indoor rides with a few additional metrics like: 1. Elevation profile: A gray elevation profile appears behind the graph. 2. Outdoor metrics: The metrics panel adds distance, elevation gain, speed, and average gradient. The tooltip also shows elevation and grade as you move along the graph. 3. Time or Distance: Use the toggle above the graph to switch the graph between time and distance. ride-analysis-11-outdoor-graph.png Rides with GPS data also include a map of your route with start and finish markers. As you move your cursor along the graph, a position marker moves along the route, so you can see exactly where on the road each effort happened. ride-analysis-12-outdoor-map.png What About Rides Without Power Data? If a ride has no power data, the power-based tabs are hidden and you'll see the Intervals tab only. You can still estimate the ride's training stress so it counts toward your training. Click Estimate TSS in the banner at the top of the page and rate the ride's intensity. For more detail, see How to Estimate Training Stress with Heart Rate Data. ride-analysis-13-estimate-tss.png More on the Ride Analysis Page - Post Workout Survey: The banner above the ride details shows your survey response, and lets you add or change one. Your responses help TrainerRoad AI adjust your training. Learn more in What are Post Workout Surveys? - AI Predicted Difficulty: For TrainerRoad workouts, this chart shows how difficult TrainerRoad AI predicted the workout would be for you. Learn more in AI Predicted Difficulty. - Workout Levels: For TrainerRoad workouts, you'll see the workout's levels and any Progression Level changes you earned. Learn more in Workout Levels. - Edit, Delete, and Download: Use the panel on the right to edit the activity's details, delete the activity, or download the ride as a .fit file. Analyzing a run instead? See How to Sync and Analyze Runs in TrainerRoad.
Your Ride Data & Progress
Training Adjustments and Notes
When you need to take time off the bike - be it due to illness, injury, or travel - add a Training Adjustment and TrainerRoad will adapt your training for your goals or events. For any other relevant information that might impact training - fuel intake, hydration status, menstrual cycle - but not require adaptations, add a Note. Screenshot 2024-10-14 at 11.59.19.png What are the Different Types of Training Adjustments and Notes? Time Off Select this option if you have any planned obligations that may interrupt your training, which may include: - Relaxing vacations - Family time around the holidays - Low-stress work functions - A much-needed break from structured training These types of interruptions are unique because, if planned carefully, they can act as recovery time, which helps to minimize their impact on your training. Injury If you sustain an injury, you should consult a medical professional to see how you can proceed. Athletes who take time off from training due to an injury need to be sensible by listening to their body (and physician if applicable), then ease back into their training load. You can account for this time away from training by selecting the Injury option, and TrainerRoad will take care of the rest. Illness If you fall ill, you should rest your body. If possible, meet with a medical professional to determine the full extent of your illness. Enjoy the time out of the saddle and use it as a break from structured training. TrainerRoad will ensure you reach your goals by taking this into account and ensuring your training is still on track by the time you can ride again. Notes Notes are what you make them! Use them to record any pertinent information that could be helpful to plan and analyze your training. As mentioned above, some athletes use Notes to track fuel intake, hydration status, menstrual cycle, race reports, etc. but you can use them however you want. Differences Between Training Adjustments and Notes Training Adjustments (Time Off, Injury, Travel) will prompt a plan adaptation if the it overlaps with scheduled workouts. Notes do not prompt an adaptation if it overlaps on a day of a workout(s). Skipping Workouts While the options above will allow you to account for scheduled adjustments preemptively, simply skipping a workout will still prompt the necessary adaptations with no extra input needed. How to Add a Training Adjustment or Note 1. Click the “+Add” button in the top right-hand corner or select the specific day on the Calendar. 2. Click the preferred option from Training Adjustments or add a Note Screenshot 2024-10-14 at 12.08.43.png 3. Enter the title of the Training Adjustment or Note. 4. Select the date range if the Training Adjustment applies to more than one day. 5. (Optional) Enter any additional information you would like to add in the "Description" box. 6. (Optional) Select the preferred color displayed on the Calendar. How to Edit an Existing Training Adjustment or Note Quick edits can be made to Training Adjustments by right-clicking on them. From here you can edit, delete and change the colour. Screenshot 2024-10-14 at 12.10.58.png To change the title or the description you'll either need to select the Training Adjustment, or select "Edit Time Off" after right-clicking on it. Screenshot 2024-10-14 at 12.13.27.png Once satisfied with those changes, select "Save" and any changes will be applied to that Training Adjustment. If there are any changes to the dates of a Training Adjustment, you will be prompted to adapt your plan to account for the change. Screenshot 2024-10-09 at 10.10.38 AM.png Note: If there are edits to the Training Adjustment other than type or date range – e.g., name or description – you will not be prompted to adapt their plan when clicking Save. How to Delete a Training Adjustment or Note Similar to above, simply right-click on the Training Adjustment or Note you want to delete and select the option to delete. Screenshot 2024-10-14 at 12.10.58.png Likewise, you can delete from the drawer by selecting the Training Adjustment or Note. Screenshot 2024-10-14 at 12.18.05.png Syncing Training Adjustments Across Platforms (Website, Mobile, Desktop Applications) You can add, delete, or edit Training Adjustments on the web, desktop, and mobile. When a Training Adjustment is added, deleted, or edited on one platform, the changes will be reflected across all platforms (i.e. web, desktop, and mobile). Image_from_iOS__3_.jpg Making a Training Adjustment on the mobile app. FAQs How does adapting around Training Adjustments help me get faster? Very few of us can execute a full season-long training plan without needing to take time away from the bike, whether for work or leisure, but taking time off the bike doesn’t have to derail your training plan or goals. By adjusting your plan to take into account the time off, you can continue to progress your training at an appropriate pace to make sustainable gains toward your goals. We help you do this by taking the guesswork out of the process and adapting automatically, so it only takes a few seconds to update your training to account for time off, eliminating stress and uncertainty. How does TrainerRoad adapt my plan to accommodate Training Adjustments? We balance your schedule constraints with progressing training at an appropriate pace, taking into consideration both the time off and your future goals. In other words, we’ll keep you on track without throwing you into something too hard right after your time off the bike. Can I delete Training Adjustments if my plan has already adapted around it? Yes. To do this, right-click on the Training Adjustment in your Calendar, then click on the trash icon to delete the time off. We will adapt your plan to reflect the changes. I deleted a Training Adjustment and got different workouts for those dates than were originally scheduled. What happened? We know it can help with motivation to keep things fresh! This means the workouts that are added back to your plan after you delete a Training Adjustment take into account a few things, including how your training has been going and ensuring to add a little variety to the mix. For example, if you’ve increased your Progression Levels since creating the initial Training Adjustment, TrainerRoad will take that into account when adapting your plan. I’m in the middle of a block, but when I added a planned vacation to my Calendar, the adapted workouts include a Ramp Test when I get back from vacation. Why is that? If your time off means you’ll go more than 14 consecutive days without completing a workout, you may want to re-test and see where your FTP settled. You can easily get back on track, but to do so effectively will require recalibrating your power zones after a period of time away from the bike. I just came down with a cold, and I’m worried this is going to mess up my training. What should I do? Go to Calendar and add a Training Adjustment. Choose “Illness” as the type, and select the range of dates you think you’ll be away from training. Save the it and adapt your plan when prompted. TrainerRoad will adapt your plan around the time off. If you don’t need as much time away from the bike as you thought, you can edit the Training Adjustment date range and adapt your plan again. TrainerRoad will adapt your plan around the shorter time off. You can do the same if you need more time off the bike; just click into the Training Adjustment and extend the date range as needed. Save and adapt your plan. I have to miss one workout this week. Should I add a Training Adjustment Training Adjustment, or just skip the workout and leave it on my Calendar? You can do either. If you add the Training Adjustment ahead of time, TrainerRoad will adapt your plan before you miss the workout. If you skip the workout but leave it on your Calendar, it will suggest adaptations the following day. The only difference will be when you see the plan adaptations; choose one method or another won’t affect how TrainerRoad adapts your plan.
TrainerRoad AI
Plan Builder is a tool that creates custom plans tailored to you and your goals. Plan Builder considers the unique demands of your goals, your available training time, and your recent training history to build a plan specific to you. Screen Shot 2024-09-16 at 1.02.29 PM.png With Plan Builder, training plans exist for just about every cycling discipline and can account for the specific needs of individual athletes. Build your custom plan and get training right away! Note: The most up to date Plan Builder is only available on the TrainerRoad website! We recommend building your custom plan on the TrainerRoad website to gain access to all of Plan Builders new functionality Plan Builder Walk-Through Plan Builder takes you through a series of steps to build you a fully tailored custom training plan. In Plan Builder, you add a start date, set goals and events for your schedule, choose how you would like to approach your training and customize your plan schedule. After Plan Builder builds your plan you’ll have the option to review it before adding your new plan to you Calendar. Customizing your plan is super easy, so let’s jump into it! Step 1: Sync Your Training History If you have any activity history, Plan Builder can use that data to help shape your plan. You can sync your activity history from Garmin Connect or Strava. If you don’t have any training history coming into TrainerRoad, don’t worry. Your plan will adjust as you progress through your workouts. How to Sync All of Your Garmin Connect Activities 1. Log into TrainerRoad to access your Account Profile. 2. Select “Activity Sync” from the menu on the left-hand side of the screen. 3. Click the option to “Connect with Garmin.” 4. Authorize TrainerRoad to access your Garmin Connect account by selecting “Agree & Connect.” 5. In Garmin Connect, authorize TrainerRoad to access your Garmin Connect account and data. If you would like a more detailed walkthrough, check out this article: Garmin Connect How to Sync All of Your Strava Activities 1. Log into TrainerRoad to access your Account Profile. 2. Select "Activity Sync" from the menu on the left-hand side of the screen. 3. Under Strava, click "Connect." 4. Read through how the TrainerRoad-Strava integration works and click "Agree & Connect." 5. Enter your Strava login credentials. 6. Authorize TR to connect with your Strava account. If you would like a more detailed walkthrough, check out this article: Strava Step 2: Choose your Goal and Start Date First you will need to let Plan Builder know if you are training to prepare for a specific event or if you would like a training plan to train for a general fitness goal. Screen Shot 2025-03-27 at 8.03.19 AM.png Once you have done this you will be prompted to choose the start date of your plan. You can start a plan at any time in the future, as long as plans do not have overlapping start/end dates with other plans. Screen Shot 2024-09-12 at 3.56.44 PM.png Step 3: Add Events or Goals Once you have chosen your start date you'll be adding your events or choosing your main goal and discipline! Select the options below for more information on adding events or choosing a goal and discipline. To Prepare for an Event This is where you will add your goal events! These can be cycling events and cycling stage races. Events can be added at these three different priority levels: - A Events are your most important events of the season. Your training plan is designed to have you at your best for these events. As such, you can only have a few A events in a year. These events have a full taper before the event with a recovery week after. A events should ideally be 12 weeks apart in order to be in peak form for both. - B Events can be seasonal objectives in their own right. They allow you to try different race prep and strategies to see what works best for you. B events receive a taper in the week of the event. - C Events are great practice and experience, but the outcome of these races should carry little value. C events will not change your plan. You can treat them like a hard workout. Screen Shot 2024-09-12 at 4.25.21 PM.png If you are unsure what races you are doing or what your final schedule is this upcoming season, no worries. You can always add events to your Calendar after your plan has been built and your plan will automatically adapt around the new additions. With that said we recommend adding at least 1 “A” priority event to your plan, when you build your initial training plan. Unsure of how to prioritize your races? Check out this blog article for more information. General Fitness Goals If you've chosen General Fitness Goals first you will be prompted to choose the length of your plan. You can choose between a 1 month, 2 month, and 3 month plan or opt for another duration! Screen Shot 2024-09-16 at 12.40.43 PM.png Once you have done this you will prompted to choose your plan's main focus by selecting your primary training discipline and your training plans primary goal: Screen Shot 2024-09-12 at 4.01.12 PM.png Step 4: Training Approach In the next step you can decide how aggressive you want your training to be by choosing your Training Approach. When choosing your training approach there are five options; conservative, moderate, balanced, demanding, and aggressive: - Conservative - A conservative approach is for athletes looking for more modest gains while benefiting from a reduced training load. This is a great approach for athletes looking to maintain their fitness or who are returning from injury. - Moderate - A moderate approach is for athletes who want steady progress and constant improvements with a comfortable and manageable training load. This is a solid option for athletes who haven’t trained in a long time or are new to the sport. - Balanced - This approach is called balanced because, for most athletes, this is the best approach to progress fitness while receiving enough recovery to remain consistent and prevent long-term fatigue. - Demanding - This is an approach for athletes who are prepared for a demanding plan and who understand their recovery needs to make progress. - Aggressive - This is an approach for athletes who want to push the boundaries of their current limits. Athletes will need to have a solid understanding of their nutrition, hydration, rest, and recovery needs for this training approach. Screen Shot 2024-09-12 at 4.29.51 PM.png Be sure to read the descriptions of each option on the slider. When in doubt we recommend opting for a more balanced approach! Once you've generated your schedule you'll be able to view your training plan! Step 5: Schedule Screen Shot 2024-09-12 at 4.39.48 PM.png Here in the schedule step, Plan Builder will automatically recommend a training schedule based on your training approach and imported training data. You will see an outline of what a general training week will look like. You can customize your schedule in the training week outline in these five ways: Dragging and dropping workouts: You can drag and drop workouts in the weekly schedule to the days of the week that you would prefer to complete them! workout move test.png Note: If you drag two workouts so they are close together you may receive a warning. Be sure to give yourself enough recovery between workouts! Changing the duration: You can change the duration of your planned workouts using the time drop down for each workout. Screen Shot 2024-09-12 at 4.44.24 PM.png Changing the workout type: You can change your indoor structured workouts to TrainerRoad Outside Workouts, Group Rides or Solo Rides, and Zwift Race from the drop-down menu. Screenshot 2025-06-09 at 10.32.31 AM.png Screenshot 2025-06-09 at 10.33.11 AM.png Adjusting amount of workouts per week: To adjust the amount of workouts per week or the number of intense workouts per week go ahead and click on the settings icon located in the top right hand corner of the weekly schedule. Screen Shot 2024-09-12 at 4.40.21 PM.png From here you can adjust how many days per week you want to train and how many intense workouts you want per week. Screen Shot 2024-09-12 at 5.12.32 PM.png Keep in mind, if you choose to do more days of training you may receive a warning that your plan has too much training load. You can restore the plan to the original settings to get you back on track by selecting Restore Schedule. Screen Shot 2024-09-12 at 5.01.59 PM.png If you'd like to tinker you can also reduce the duration of workouts, or change how many intense days you have per week to get your desired training schedule. Restoring your Original Schedule If at any point you'd like to restore your plan back to the initial recommendation go ahead and select the Restore option located to the right of the settings button and then hit Restore Schedule: Screen Shot 2024-09-12 at 4.55.29 PM.png Screen Shot 2024-09-12 at 4.58.40 PM.png Step 6: Name your plan and Review! Finally you can go ahead and give your training plan a name, and take the plan to review! Screen Shot 2024-09-12 at 5.04.53 PM.png You will see a breakdown of your custom training plan with details of your schedule and an overview of your plan phases and when they start, before you add the plan to your Calendar Screen Shot 2024-09-12 at 5.06.36 PM.png Your plan will be composed of these three different phases: - Base Training Phase is where it all begins. It's the foundation of cycling and triathlon success, developing resilient aerobic fitness and laying the groundwork for higher-intensity, discipline-specific training later on. The importance of base training can't be overstated. - Build Training Phase builds discipline-specific fitness on your aerobic foundation, pushing you out of your comfort zone to increase your sustainable workload and make you faster. - Specialty Training Phase Focuses your training on the specific demands of your goals and/or events. This is a demanding discipline-specific final block of training. FAQ What if I already have events on my calendar? Plan Builder will detect events already on your calendar, and ask you to "Include" them once you reach the “Events” step of the process. What if I need to add events later? No problem! When new events are added after a custom plan has been added to the calendar, we’ll ask you if you would like those events to be accounted for in your plan and edit the plan to better fit that event. What if I need to take time off? You can add time at any point in your TrainerRoad Calendar once your plan is built. Learn how here: How to Add Time Off to My TrainerRoad Calendar What if I’ve already started training? Go ahead and choose a start date when you actually started training, even though it's in the past. This will make the plan automatically start where you were in your training! Why does my plan go Base/Build/Base? In your plan, when you have extra time before your goal event, alternating between Base and Build phases ensures your body stays responsive and well-prepared for your target event. Utilizing the Base phase after building fitness allows you to reduce fatigue, prevent plateaus, and enter your Specialty phase with the energy needed to maximize your event-specific gains. TrainerRoad Base training is not the same as Traditional Base training. So when TrainerRoad Base training is used after a Build phase, it does not revert the plan to significantly easier Z1/Z2 training. Instead, it strategically shifts your training to maintain progression while giving your body the necessary preparation for the final push into the Specialty phase. Note: If your plan is long enough, alternating between Base and Build serves the same preparatory function mentioned above. I got a different volume than what I’ve been doing, why is that? Your recommendation is customized for you based on your current capabilities as an athlete, your goal, and your Training Approach. If you are seeing a different volume than what you have been doing you might’ve been doing too much volume before, or not enough. Why did my long Endurance ride change to a Solo Ride? We recommend doing particularly long Sunday Endurance rides outside. You’ll notice that your training plan’s Solo Ride still has wattage/RPE targets and instructions on how to ride so that you can maintain the same goals as your scheduled workout. How do you know which training plan and schedule is best for me? We do a deep analysis of all of your data to intelligently recommend how much volume, intensity, and recovery you need. Where are Masters plans? Masters plans are training plans with one less day of intensity per week. You can adjust how many intense days per week your training schedule has. To do this open the Settings panel to change between 2- and 3-days of intensity per week. Masters should use 2-intense workout plans. Can I adjust the total amount of workouts per week? You can adjust how many workouts per week your training schedule has. To do this open the Settings panel to change between 2-6 workouts per week. We highly suggest using our customized training schedule recommendation, though. How can I make a plan for maintaining fitness? When you start building a plan, you will be asked if you want to build a plan for an event or fitness goals. If you would like to build a plan to maintain fitness, select fitness goals, then select your discipline and choose “Maintaining Fitness” as your goal. This will build a plan focused on maintaining your specific level of fitness. Can I make workouts too long or too short? If you edit your plan in a way that would be detrimental to your fitness goals, or ability to complete the plan, you’ll see a Warning banner on the page. This means your plan schedule is not recommended. Changing workout durations to be shorter than the initial recommendation, isn’t necessarily a bad thing, but you may be able to handle more than you think! I'm not trying to win races, but I do want to get into better shape. Is there a plan for that? Yes! Plan Builder can build plans structured around your primary discipline and goals. How does the PBv2 work for athletes who don’t have a target event? Plan Builder can build plans structured around your primary discipline and goals. How do I balance my strength training and other activities with my TrainerRoad Plan? Does Plan Builder consider strength training or cross-training? If you don’t have Activity Sync set up with TrainerRoad, we recommend getting that set up so that all of your training, strength training included, is imported to TrainerRoad. If you do anything that would lead to long-term burnout, TrainerRoad AI will adjust your TrainerRoad workouts down or prescribe a Rest Day. Will my current training plan change with the update? You’ll see the option to optimize your current custom plan if you have one added to your Calendar. You can always update your Training Approach and Training Schedule by clicking on the plan name or plan annotation from your Calendar. How can I update my plan if my goals or schedule change? You’ll see the option to optimize your current custom plan if you have one. You can always update your Training Approach and Training Schedule by clicking on the plan name or plan annotation from your Calendar. Where can I use the new Plan Builder? You can use the new Plan Builder on the TrainerRoad website! Can I use Plan Builder if I have limited time to train? Yes! You can even make plans with only 2 workouts per week. You can adjust the duration of any workout to be shorter if you want. Will Plan Builder re-build the plan if I add new events after the plan has started? Yes! Plan Builder will adjust around any event added to your Calendar. Can I still choose specific training phases (Base, Build, Specialty) manually? Yes! You can still add individual training phases to your Calendar. To add individual Training phases to your Calendar select Training Phases at the Training Plans page. I'm training for an event but I don't know the exact dates yet. What should I do? If you aren’t sure what the exact dates of your priority events are you have a couple of options! Add the event to your plan with an approximate date of when it may be. Once you know the date, update the event date on your Calendar and we’ll ask to update your plan to peak your fitness for your event. Build a plan without an event, selecting the event’s discipline and your personal goal. Once you know the date, add the event to your Calendar and we’ll update your plan to peak your fitness for your event. Are Triathlon plans supported? You can build a training plan with Plan Builder! There are some differences in the steps when you build a triathlon plan with Plan Builder instead of a cycling plan. Can I make a Polarized plan with the new Plan Builder? Currently you cannot build a Polarized Plan Builder plan. The good news is that this is something we are hoping to implement in the future.
ANT+ USB Stick Troubleshooting
If you're experiencing issues pairing your ANT+ devices to TrainerRoad, you're in the right place to get some help. This article will help you identify problems with your USB stick or your computer. These are the same steps that our support crew use when you e-mail us, so please make sure you try these steps before contacting us. If you are unsure of what you need to use ANT+ devices with TrainerRoad, you can learn all about it in the ANT+ article. Step 1: Plug the ANT+ USB Stick into Your Computer or Device This is what you will see if the ANT+ USB stick is not plugged into your computer's USB port or is not recognized. If the ANT+ stick is plugged in and still not recognized, there may be something wrong with the stick or your computer's USB port. Screen_Shot_2020-05-15_at_10.24.12_AM.png Step 2: Install Device Drivers If you're on a PC, make sure you've installed the ANT+ USB Stick and Bluetooth Drivers. For Mac users, there is no need to install these. Apple computers come with the necessary drivers already installed so you can skip this and continue to the next step. How to Check for Installed Drivers To check if the drivers are installed, go to "start" and type "Device manager". Load the program called device manager. The device might be displayed in two different locations. libusb-win32-devices Universal Serial Bus controllers Trouble installing drivers? If it looks like the drivers won't install, the next step is to try another USB Port. If that doesn't work, try installing the drivers on another computer. If you still can't install the drivers on another computer, it is likely that you have a bad ANT stick and will need a new one. If you have access to another ANT+ USB stick, try that on both computers and see if the drivers will install. It's also possible the driver was corrupted or changed by your OS or another software program. To fix this, you can uninstall your device drivers and perform a fresh install by following the instructions on this page. Drivers install on another computer, but not the one you train with? We've seen this a few times and there's not much we can do. There is likely a system-level problem keeping you from installing the drivers for the USB stick. A refresh of the operating system is often needed. This is depressing, I know. This occurs because there is a system-level problem between the operating system and Garmin's drivers for the ANT+ stick. Make sure that you test that ANT stick on more computers and USB ports on your computer before you reach this drastic level of refreshing your OS. Step 3: Check for Conflicts If the drivers are installed properly, but TrainerRoad cannot find the ANT+ USB stick, there may be conflicting programs as only one program can access the ANT+ USB stick at a time. Check for Garmin ANT Agent, or Garmin Express in the system tray. If that program is on, make sure you exit it. See screenshot examples below, or watch this video on How to Disable Garmin ANT Agent. With Garmin Express, you'll need to make sure that it's closed fully, and not running in the background, which it can default to. Check your system taskbar to ensure that it isn't running. If it is still in your taskbar, follow the images below to exit it. Garmin Express (PC) Garmin Express (Mac) Garmin ANT Agent (Mac) Make sure to select "Quit" to exit out of Garmin Express entirely. Garmin_Express_Quit_PC.png Have an Acer or other computer with Soluto installed? We've seen some pre-installed software on Acer computers (and some others) that mess with ANT+ USB sticks. If you have an Acer computer, you can manually stop these interruptive programs. 1. Go to start, then type "taskmgr". 2. Go to the process tab and look for something called "Soluto". 3. If you see that process, click on it and click "end task". 4. If that fixes the problem, you'll want to use the Soluto uninstall tool and remove it from your computer. Note: If you can't download the Soluto Uninstall Tool above by clicking it, please try right-clicking it and copying the link address to open it in a new tab. Step 4: Check if Garmin Express Can Detect the Stick If TrainerRoad can not find the stick, and there are no conflicting problems then we want to test the stick in Garmin's software to make sure it works. Open Garmin Express and locate it in the system tray (PC) or taskbar (mac), and click to open it. Make sure to close out of the Garmin Express window once done testing, and to close it from the taskbar as shown in the photos above. Working: Device is Connected and Active PC Example garmin-ant-agent-working-stick.PNG Mac Example Not Working: Device is Not Connected and Inactive PC Example garmin-ant-agent-not-working-stick.PNG Mac Example What do I do if Garmin ANT Agent/Express does not detect the ANT+ USB Stick? If the drivers are properly installed and Garmin ANT Agent/Express can't detect the stick, you'll want to repeat the process on another USB port on your computer. If you get the same result try it again on another computer. If you can't get TrainerRoad or Garmin ANT Agent/Express to detect the USB stick, you likely have a bad ANT stick and should return/exchange it from your place of purchase. Windows 11 ANT+ Drivers After updating to Windows 11, Athletes may lose the ability to pair with their ANT+ devices. This is because ANT+ drivers do not come preinstalled with Windows 11. To get ANT+ drivers on your Windows 11 PC, follow the steps below. 1. Windows Settings" ⚙️, open Updates and hit Check for updates. Note: If it already says you’re up to date, you will still need to prompt a new check. 2. In theAdvanced Options menu, click on ‘View optional update 3. Expand the list of driver updates. Locate the ANT+ driver (it shows up as Dynastream Innovations), select it, and press ‘Download and install’ to complete the process. This should get you the correct drivers. Some athletes get a notification in their notification panel asking them to finish installing the drivers. If this happens to you, confirm the installation, and you should be set! Still having problems? If you've gone through all the steps above, shoot us an email at [email protected]. To help us with the ticket, please let us know your username, your operating system, your computer brand, how the above steps went for you and what kind of ANT+ USB stick you have, details below to figure out what kind of stick you have. Don't know which type of USB stick you have? There are two kinds of ANT+ USB sticks to choose from: USB 1.0 and USB 2.0. USB 1.0 can connect up to 4 devices at a time, while USB 2.0 can handle up to 8. Most newer sticks will be 2.0 since 1.0 is no longer in production. For more information on how ANT+ works with TrainerRoad and which dongles we recommend, please visit the article on ANT+ Connectivity.
Pairing & Connection Problems
Plan Builder FAQs
If you don't see the answer to your Plan Builder question down below, please reach out to [email protected] for more information on Plan Builder. General What is Plan Builder - Plan Builder creates a custom training plan that brings you to peak fitness for your goal event or discipline. Plan Builder takes into consideration your goals, how much you want to train and when, all of the events on your training calendar, and the demands of your goal event to give you a truly customized training experience. Why Plan Builder? - Plan Builder accounts for all of the unique variations in your training schedule, event schedule and lifestyle that might affect the progression of your training plan. By adjusting your training plan in accordance with your needs your plan will be easier to follow and ultimately more effective. Where Do I Start? - If you don’t have a training plan, you can jump straight into Plan Builder. 1. To start constructing your custom training plan, first, go to your online career. 2. Select the Training Plans tab in the navigation menu on the left-hand side of the screen. 3. Select Build Create My Custom Plan to launch Plan Builder. Screen Shot 2025-01-16 at 11.30.13 AM.png Is Plan Builder available in the TrainerRoad app? - Athletes can build their custom Plan Builder plans via the desktop apps or the TrainerRoad Website. With that said, we recommend building your training plan on the website as the website's version of Plan Builder has added functionality. - To use Plan Builder from within the desktop app, make sure you're on the latest app version, then go to the Training Plans section of the app. How Plan Builder Works How did you come up with the recommended training volume? - The recommended training volume is based on your training approach and the amount of training you have completed in the past few weeks of training. I want to start my training plan in the past. Can I do that? - Yes! If you have already started training you can backdate the plan by selecting the date you started training this season. Why didn’t Plan Builder suggest the Base, Build and Specialty phases in order? - It is very rare that your available training time will perfectly align with the length of a Base, Build, and Specialty Phase training progression, so adjustments need to be made. When these adjustments are needed, Plan Builder uses the latest sports science research and millions of training data points to create the ideal training progression to bring you to peak fitness. Why is Plan Builder suggesting I go back to the Base Phase in the middle of my plan? - In many cases, athletes with less experience doing structured interval training benefit most by spending more time in the Base Phase. Additionally, a mid-season return to base training can allow the body to recover from more strenuous forms of training, and reach new heights by entering a base phase with a higher FTP. Why is Plan Builder suggesting I go to a Specialty Phase in the middle of my plan? - Plan Builder strategically uses different training phases to increase fitness and freshness in order to make you as fast as possible for your goal event. In many cases, the Specialty Phase can be a great opportunity for the body to increase freshness without losing fitness. This is particularly true for athletes with a lot of experience doing interval training and serves as a great mid-season reset point for any rider, especially during long training progression Why is Plan Builder suggesting I do more than one Build Phase? - Athletes that have a moderate level of experience with interval training can benefit from more time spent in the Build Phase to fully reach their potential. Doing too many weeks in a row of Build training can be extremely fatiguing, so Plan Builder will split up excessively long Build Phases with a Base or Specialty Phase. Events What if I don’t have any goal events? - No events, no problem! If you aren't training for an event you can build a goal Based training plan. What if I have multiple priority events? - You can add as many C events and B events as you’d like, but A events (priority events) must be spaced eight weeks apart. Anything less than 8 weeks between goal events won’t allow you enough time to recover and rebuild sufficiently to reach peak fitness once again. - If you have two priority events within 8 weeks of each other, evaluate which event is not as important and make one event an A event and the other event a B event. You will still have rest allocated before the B event but you will only have a taper and a peak for the A event. What if my priority event is a multi-day event? - If you are training for a multi-day event, mark your event as a ‘Stage Race’ when you categorize the discipline of your event My stage race includes multiple disciplines. Which should I choose for "targeted discipline" - Mark the event you’d like to prioritize as the targeted discipline. You’ll taper for the entire stage race, but your Specialty training will be geared towards your targeted discipline. What if I already have events on my Calendar? - If you already have events on your TrainerRoad calendar Plan Builder will accommodate these events. If you’d like to start fresh you can delete the current events on your Calendar and add them when you use Plan Builder. For more information on how to delete events check out this help center article: Editing Your Calendar What if I need to add events later on? - New events can be added at any time. If you would like to add additional events to your TrainerRoad Calendar go ahead and check out this help center article: Add A/B/C Priority Events What if my goal event is more than a year away? - Plan Builder will create a training plan for any event within two years of the day you’ll start training. What do you mean by A, B and C Events? - Categorizing your events as A, B and C events is an easy way to prioritize the importance of your events. For more information on prioritizing events go ahead and check out this help center article: Prioritizing Races (A, B & C Races) Do I need an A Event for Plan Builder? - If you plan on racing, at least one of your events should be an A-priority event. If you aren’t sure which event you would like to make your A event check out this help center article on prioritizing events: Prioritizing Races (A, B & C Races) What if I want to train for a whole series of events instead of just one event? - If you are training for an entire series, we still recommend you make one event within that series an A race, and marking the rest as B races. This will allow Plan Builder to bring you to peak fitness. Plan Builder will build in tapers, rest and openers around the existing events, so your training will be kept on track. I don’t know what sort of event my race is. What should I pick? - If you don’t know what sort of event your race is, select the discipline that is closest to the type of event you plan on racing. I am training for a time trial distance other than 40k. Does Plan Builder work for that? - Yes. When creating the event, enter the event duration and intensity and Plan Builder will take care of the rest. Adjusting Your Custom Plan What if I need to take time off? - When you need to take time off you can edit your Calendar to adjust for time spent off the bike. For detailed instructions on how to edit your training plan check out this help center article: Editing Your Calendar What if I have already started training? - You can use Plan Builder even if you are in the middle of a training plan right now. First, you will want to delete your current training plan from your Calendar. For detailed instructions on how to delete a custom training plan check out this help center article: Delete/Unschedule a TrainerRoad Plan - When you add your custom plan to your TrainerRoad Calendar go ahead and choose the day you started training for your current season. When your custom plan is added to your Calendar, it will include the workouts you have already completed this season. How do I start over, clear my calendar, and create a new Plan Builder plan? - If you already have a training plan added to your TrainerRoad Calendar you will want to delete (or unschedule) this training plan before you build your new custom plan. Note that this will only delete planned workouts - any workouts you have completed will be saved. For detailed instructions on how to delete a custom training plan check out this help center article: Delete/Unschedule a TrainerRoad Plan What happens to my current training rides if I delete/unschedule my current training plan? - When you delete your current training plan to add a custom plan all of your completed workouts will remain on your Calendar. What happens to my A/B/C priority events if I delete my new plan? - If you delete a plan created through Plan Builder, any events that you added to your calendar via that plan will remain on your calendar. If you create a new plan, you can add these events to your plan by clicking the "Include" button in the Existing Events section of Plan Builder. Should I take the Ramp Test before I start Plan Builder? - The Ramp Test will automatically be the first workout in any training phase or plan. If you are just starting a TrainerRoad plan, we definitely recommend starting off with this workout. If you have recently completed a Ramp Test in another training plan you can skip this Ramp Test at your own discretion. I don’t have much time until my goal event. Can Plan Builder create a training plan on a short timeline? - Absolutely! Plan Builder will build a training plan for your goal event, as long as you have at least one week until the event. I want to train on different days than Plan Builder suggests. Can I change that? - Definitely. You can customize the schedule of your training week during the "Schedule" section of creating the plan. Simply drag and drop your training days. Can I decide which days I want to train outside? - Yes! When you create the schedule for your training plan you can mark specific days in your training week as outside rides. You can do this one by one, or adjust this per training block when building your custom plan. After your plan is made, you can change any workout to be an outside or inside workout on the fly. Can I change my training volume halfway through my plan? - You can change the number of days in your training plan at any point after Plan Builder has made your custom training plan. To change the training volume of your plan after it has been built, follow these steps: 1. Go to your online career. 2. Select the Calendar tab in the menu on the left-hand side of the screen. 3. Navigate to your current training block, or the block you are about to start. 4. Select the Block on your Calendar: 5. In the menu that appears on the right select 'Edit Weekly Schedule' 6. Adjust your training schedule in the subsequent steps. Can I make changes to my training plan once I’ve added it to my calendar? - Absolutely, your training plan can always be edited. You can add additional events, swap workouts, edit training weeks and even delete workouts. For detailed instructions on how to edit your Calendar go ahead and check out this article: Editing Your Calendar
