You can customize what TrainerRoad workout data is shared to your Strava account through workout images in the Strava Sharing Settings in TrainerRoad.
How to Update Strava Sharing Settings
Once Strava is connected to TrainerRoad via Activity Sync, you can access and manage workout images synced to Strava through the Strava Sharing Settings. To do this follow these steps:
- Select the Account tab from the Navigation menu.
- Select Activity Sync.
- Under the Strava box select Settings.
- Here you can adjust these image related settings:
Share Workout Image
- If this is toggled off, TrainerRoad won't send any images to Strava
Include Progression Levels
If this is toggled off, TrainerRoad will send the new redesigned workout image but without the Progression Level chart.
Note: these are both toggled ON by default.
