Which Version Do I Need - the Legacy App or the Legacy AIR App?
There are two old versions of the TrainerRoad App.
- The Legacy App
- The Legacy AIR App
The Legacy version required will depend on your trainer and operating system. Below is breakdown the factors that will determine which app's right for your setup.
Setups that Require the Legacy App
- Operating System
- Windows 7.
- macOS X v10.10 Yosemite or earlier.
- Trainer
If you need the Legacy App, scroll down the section: What is the TrainerRoad Legacy App?
Setups that Require the Legacy AIR App
- Operating System
- Athlete's using CompuTrainers on macOS 10.15 Catalina or greater.
- Trainer
If you need the Legacy AIR App, scroll down the section: What is the TrainerRoad Legacy AIR App?
The TrainerRoad Legacy app is an older version of the TrainerRoad app.
- It is only available for Desktop. There is no Legacy app for iOS or Android.
- It is a locked version of the TrainerRoad app. No updates are made to the app.
- It does not allow you to modify the Calendar, but the Calendar is viewable from within the app.
- It does not include all the same features of the latest app (Adaptive Training, TrainNow, Plan Builder, Group Workouts, or the Ramp Test)
- It does not support Native Bluetooth on Windows. Therefore, pairing devices in Windows via Bluetooth requires a Bluegiga BLED 112 Bluetooth dongle.
Setups That Support the Legacy App
If you need to download the Legacy App because your trainer is not compatible with the latest TrainerRoad app, you'll need to ensure your operating system supports the Legacy App. Check out the requirements below.
Windows
- Microsoft® Windows 7, 8, 10, or 11.
- To pair devices to the app, athletes require either:
- An ANT+ USB Dongle, or;
- A Bluegiga BLED 112 Bluetooth dongle.
- The Legacy app does not support Native Bluetooth on Windows.
Mac
- macOS v10.4 Mojave or earlier.
- macOS v10.5 Catalina or greater cannot run the Legacy app.
- Native Bluetooth is supported.
- To pair devices to the app via ANT+ athletes require an ANT+ USB Dongle.
How to Download and Install the Legacy App?
You can download the Legacy App for your operating system from the links below:
- TrainerRoad Legacy App
If you run into any problems installing the app, please contact support@trainerroad.com and we can help out!
The TrainerRoad Legacy AIR app is an older version of the TrainerRoad app that runs on Adobe AIR.
- It is only available for Desktop. There is no Legacy AIR app for iOS or Android.
- You need to download Adobe AIR in order to run the Legacy AIR App.
- It does not include all the same features of the latest app (Adaptive Training, TrainNow, Plan Builder, Calendar, Group Workouts, or the Ramp Test)
Setups That Support the Legacy AIR App
If you need to download the Legacy AIR App because your trainer is not compatible with the latest TrainerRoad app, you'll need to ensure your operating system supports the Legacy AIR App. Check out the requirements below.
Windows
- The Legacy AIR app does not support Native Bluetooth on Windows.
Mac
- macOS v12 Monterey or earlier.
How to Download and Install the Legacy AIR App?
You can download the Legacy AIR App & Adobe AIR for your operating system from the links below:
- TrainerRoad Legacy AIR App
- Adobe AIR
- Adobe AIR Download
- Note: this link will take you to the Harman website (the company that provides the Adobe AIR runtime) where you can download Adobe AIR for Mac or Windows.
